Quik-Latch Hood pins
Old 03-10-2014, 02:32 PM
Torch_Vert
Torch_Vert's Avatar
Default Quik-Latch Hood pins
Just finished this project up this past weekend. Really love 'em. Holds the hood solid as a rock, and no loose pins to lose or lanyards to mess up the paint:
Torch_Vert is offline
Old 03-10-2014, 02:34 PM
Derf00
Gentleman's Relish
Derf00's Avatar
so how do they release, Push button?
Derf00 is offline
Old 03-10-2014, 02:36 PM
Torch_Vert
Torch_Vert's Avatar
Yup
Old 03-13-2014, 02:21 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Very clean, I like them
Looks less obtrusive than these which I've been considering...
http://www.aerocatch.com/
How much were yours or are they a custom job?
Derf00 is offline
Old 03-13-2014, 02:32 PM
Torch_Vert
Torch_Vert's Avatar
I actually bought a set of Aerocatchs, looked them over and ended up selling them on eBay. Construction on them was ok, but the visible portion on the hood looked too "import tuner-ish" for an S197 in my view, and the pins under the hood were pretty ugly in my opinion (I do shows, so how things look with the hood open counts). The Quik-Latch pins are very unobtrusive, look slick, and their spherical tops are not going to disembowel you if you need to lean over them for engine chores.
Quik-Latch pricing is definitely higher, but for construction you're looking at mostly plastic for the Aerocatch vs machined aluminum and polished stainless on the Quik-Latch.
Can't give you an idea on install, as I did mine entirely myself except for having a skilled welder TIG the inserts I made into the radiator support (that ran $40)
Old 03-13-2014, 05:57 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Lol, I'm doing those on a 68 Camaro right now...
Did you put a brace under the hood skin for reinforcement?
Cause if not, it's gonna suck it in eventually.
pascal is offline
Old 03-13-2014, 06:39 PM
Stangette
Stangette's Avatar
Those are sweet, do they come in chrome?
Stangette is offline
Old 03-13-2014, 06:45 PM
Torch_Vert
Torch_Vert's Avatar
No, but they do come in mirror polished aluminum
Old 03-13-2014, 06:49 PM
Torch_Vert
Torch_Vert's Avatar
Not too likely Pascal. The hood is pretty thick fibreglass, but I know what you mean on the stock aluminum hoods.
I did add some reinforcing rings to the underside though, but more to spread any shock from the hood closing and pins engaging over a wider area.
Old 03-13-2014, 06:54 PM
pascal
pascal's Avatar
I've seen it happen on fiberglass too but you should be OK if it's thick enough indeed.
pascal is offline
Quick Reply: Quik-Latch Hood pins
