LED replacement of stock instrument panel bulbs?
Old 11-14-2014, 06:56 PM
BinaryFu
BinaryFu's Avatar
Question LED replacement of stock instrument panel bulbs?
I have a stock V6 Mustang w/o MyColor and I was thinking of swapping out the stock bulbs with either white or blue LED bulbs (194, I believe?).
Are there any howto guides for doing this? Every guide I've found for *anything* with the dash has been either "This is how you take off the instrument panel" (Always good to know) or "Let's skip seeing all the stuff BinaryFu wants to see and get right into the circuit board!!!" *sigh*
So, I'm presuming it is completely doable, I have a lovely set of bulbs waiting to be used, I would just like to be able to look over a howto while recovering from the flu before I go out there and do it.
Cheers,
BinaryFu
BinaryFu is offline
Old 11-14-2014, 07:16 PM
ThaiCobra
ThaiCobra's Avatar
I have always wanted to do this in my stang. I want to redo everything that is green and make it red. Including the stereo panel, and the info panel in the gauge cluster.
There is a thread somewhere on one of the other mustang forums where a guy did it. From what I remember taking everything apart was the hard part. Also you have to solder the new LED's in, they don't just snap on. Then everything needs to carefully be put back together.
I'll look for the thread and if I find it, I'll post the link. Good luck. Keep us updated.
ThaiCobra is offline
Old 11-16-2014, 02:09 AM
BinaryFu
BinaryFu's Avatar
If you can find the howto for that, or how to set up footwell lighting to work off the map lights, that would be greatly appreciated. I'm trying to figure out the best way for routing the wiring and mount points, as well as doing the gauges. :-)
BinaryFu is offline
Old 11-25-2014, 04:06 PM
ABQstang89
ABQstang89's Avatar
Im pretty sure that you can put the LEDs on backwards when soldering them on so be careful. As for the map lights that is simply a bulb replacement. For the footwells just find some led bars or neon bars you like with a cigarette lighter attachment. Cut and splice into an add a fuse and place in passenger foot well fuse box.
ABQstang89 is offline
Old 11-26-2014, 09:19 AM
BinaryFu
BinaryFu's Avatar
You may have misunderstood, I'm looking to link the foot well lighting to the map lights so they come on the same times the map lights would, including when they are manually turned on.
It's alright, I'm pretty sure I know what needs to be done, I would have just liked a walk through to verify my theories.
As for the dash lights, they sound like they're soldered, which isn't a bad thing, just horribly time consuming to make it happen (polarity has to be verified for each before soldering can occur).
I'll try to create a how to when I get around to doing these projects, so others will have something to go by.
BinaryFu is offline
Old 11-26-2014, 03:06 PM
ABQstang89
ABQstang89's Avatar
I see what you mean now. Just from looking at the manual real quick the light green and yellow wire running to map lights is the control wire for them.
Diode Dynamics
28
05-26-2022 12:02 PM
daytooday
05-02-2018 07:22 PM
kdryan
08-21-2015 04:01 PM
inyadreems
08-21-2015 09:10 AM
philster0306
08-10-2015 11:33 AM
Quick Reply: LED replacement of stock instrument panel bulbs?
