I finally cut into the hood
Old 10-08-2015, 04:38 PM
flash_xx
flash_xx's Avatar
Default I finally cut into the hood
Took me a few days to work up the courage to do it but it was well worth it for the track day outings. Car was overheating after a few laps.
Next up brake duct cooling and front splitter
flash_xx is offline
Old 10-20-2015, 06:16 PM
Stoenr
Stoenr's Avatar
Under hood pics!! Glad it worked out, don't think I could do it, lol.
And yes, these beast overheat on the track. constant 4500-6800 rpms full throttle or full braking, I was overheating too!
Gauge would start to climb, I would have to let it coast in the straight, but that didn't last long. And this was only on a real hot day.
Stoenr is offline
Old 10-21-2015, 11:52 AM
movielover40
movielover40's Avatar
Too bad you had to cut it but it turned out well...
movielover40 is offline
Old 10-28-2015, 11:10 AM
SCCAGT
SCCAGT's Avatar
I agree, looks great.
I really wish someone made a direct fit GT500 hood that would fit properly to a regular GT.
I do not particularly care for the Super Snake style. Not as subtle.
SCCAGT is offline
Old 10-29-2015, 09:35 AM
flash_xx
flash_xx's Avatar
The mod works really well, it also helps with hood lift at speed. Before it used to bulge, not it just stays put. I really hated having to cut into the hood, but honestly, I don't plan on selling it until it's literally falling to pieces, and by then, whoever buys it will just have to deal with the hole
flash_xx is offline
Old 02-29-2016, 09:44 AM
cema93
cema93's Avatar
Looks good but could u have upgraded the cooling system and used better coolant?
cema93 is offline
Old 02-29-2016, 03:06 PM
SCCAGT
SCCAGT's Avatar
A bigger/better radiator is the only 'upgrade' available, and I believe he has already done that. Coolant is coolant...wont change anything.
Airflow through the radiator is what is more beneficial, and this vent accomplishes that wonderfully.
SCCAGT is offline
Old 04-25-2016, 01:20 PM
svastano
svastano's Avatar
Looks great!
svastano is offline
Old 05-02-2016, 06:16 PM
birdoffire7
birdoffire7's Avatar
Looks good.
birdoffire7 is offline
Old 05-05-2016, 07:32 AM
flash_xx
flash_xx's Avatar
Thanks, it's an easy although nerve wrecking mod that does reduce under hood temperatures. Fully functional and very cheap. Plus, no crappy fiberglass hood can match the weight of the oem hood.
flash_xx is offline
fastbackford351
10-23-2015 06:23 AM
dba Brakes
10-08-2015 01:34 AM
seanwillis0826
10-07-2015 03:46 PM
ushiee
10-07-2015 09:51 AM
Curls&Horses
10-06-2015 09:09 PM
Quick Reply: I finally cut into the hood
