Sponsored by:
Sponsored by:
Old 10-23-2015, 03:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
Print Wikipost
2006 GT Fuel Filter Replacement
Old 09-11-2006, 06:24 PM
jimSD63
jimSD63's Avatar
Default 2006 GT Fuel Filter Replacement
How do I change the fuel filter on my 2006 mustang GT? I did a search and couldn't find out.
Thanks, jk
jimSD63 is offline
Old 09-11-2006, 06:39 PM
rebelyell06
rebelyell06's Avatar
Default RE: 2006 GT Fuel Filter Replacement
Very annoying process. You gotta jack the car up on the driver side and there is a skid plate around the door area under the car. Take it off and there's the filter.
rebelyell06 is offline
Old 09-11-2006, 08:06 PM
MBDiagMan
MBDiagMan's Avatar
Additionally, I expect that these Fords still have the push on connections that require a special tool The tool is basically a sleeve that fits over the line and slides into the line to release a spring that goes around the filter stub. When you purchase the tool, don't get the plastic ones. Get the scissors looking type that is made of metal.
Good luck.
MBDiagMan is offline
Old 09-11-2006, 08:43 PM
hawgman
I ♥ Acer
hawgman's Avatar
No push on tool necessary. Just a couple of metric wrenches.
hawgman is offline
Old 10-02-2011, 03:22 AM
Bluebeast77
Bluebeast77's Avatar
Get the scissor tool. It will make life easier. The green retaining clips are not removable like many instructions claim. The tool is used to spread the green retainer so that the lip of the fuel filter can slip right out. I had to find that out the hard way. I broke one of the clips trying to remove them. The tool cost $6 from northern tool. You may find the tool at your local auto parts store. The tool has two sides, one for 5/16 fuel lines and the other side is for 3/8 fuel lines. Use the 3/8 side. Good luck
Bluebeast77 is offline
Old 10-02-2011, 07:32 AM
IndecisiveS197
IndecisiveS197's Avatar
No tool necessary. All you need to do is take a flathead screwdriver, put it on top of the green part of the connector and push down.
Everything should just pull apart when you push down on that little green piece. I just did mine a month ago.
IndecisiveS197 is offline
Old 10-02-2011, 08:29 AM
kput
kput's Avatar
I did mine myself awhile back. It's simple..and I have no mechanical skills, lol.
Take out your fuel filter fuse (google to find out which),
then try to start your car a few times. It'll drain some of the fuel out of the line.
Jack up the drivers side and use a wrench to get the plastic case down out of your way.
Get a cup or something to drain the little fuel you'll get into.
I used my fingers to push the green clips and release the filter. No biggy.
Then make sure the filter is facing the right way, slip the hoses on,
bam good to go.
kput is offline
Old 10-02-2011, 08:58 AM
SON OF 68
SON OF 68's Avatar
SON OF 68 is offline
Old 10-02-2011, 02:58 PM
tx_zstang
tx_zstang's Avatar
Exactly.
THESE ARE NOT THE SAME OLDER-STYLE CLIPS FORD USED TO USE!!!
Do NOT try to pull them out, like I did, and break one apart.
Push in on the green tab and pull apart.
tx_zstang is offline
Old 10-02-2011, 09:22 PM
robs
robs's Avatar
Yeah.. don't be a dumas and pull it out like I did and break the damn thing!! Screw driver and push it IN and it's a no brainer..
robs is offline
Quick Reply: 2006 GT Fuel Filter Replacement
