Sponsored by:
Sponsored by:
Some specs & Comparisons
Old 09-17-2004, 04:10 AM
Guest
Guest
Posts: n/a
Default RE: Some specs & Comparisons
ORIGINAL: kevin02
here is the problem i saw. the 03 mach 1 had more hp and tq and weighed less. so how is the 05 faster in the 1/4? i was just lookin at the comparisons
Gearing perhaps?
The 05 only has 5 less hp and tq with 5 lbs of weight over the Mach I... with a supposed .1 second difference in the 1/4.
That isn't going to make that much of a difference, however... the numbers I've been seeing from stock Mach Is are nowhere near as high as 14.0s.
Old 09-18-2004, 04:33 AM
kevin02
kevin02's Avatar
i dint think the machs were that high either. i have 1 and i know for a fact it isnt a friggen 14.0 lol. arnt there some people on this board than ran like 13.2's 13.3's in stock mach?
kevin02 is offline
Old 09-18-2004, 01:04 PM
RollinThunder
RollinThunder's Avatar
a guy at my track was hitting 13.5's with just a catback and CAI...and his best run was a 13.2
RollinThunder is offline
Old 09-22-2004, 12:30 AM
Stinger
Stinger's Avatar
Yea that sounds about right.. Those are Stock LS1 times.
Stinger is offline
Old 09-23-2004, 01:11 AM
matthockey32
I ♥ Acer
matthockey32's Avatar
the weights of the cars is all wrong as well. the mach 1 weighs 3460 lbs. the GT weighs 3390 lbs and a cobra weighs 3730 lbs. the new GTs weigh about the same as the mach 1, estimated at less than 3450 lbs, and have 5 less hp and 20 less lb-ft of torque. i am estimating mid-high 13s in the 1/4 mile based on the info that i have and depending on the driver.
matthockey32 is offline
baddog671
07-26-2016 01:20 PM
robcy
Suspension
10-27-2015 11:14 PM
09-23-2015 01:28 PM
EASTIDEE123
09-14-2015 03:52 PM
Webster454
09-07-2015 04:59 AM
Quick Reply: Some specs & Comparisons
