Sponsored by:
Sponsored by:
Some specs & Comparisons
Old 09-01-2004, 01:46 PM
ricekiller2003
ricekiller2003's Avatar
Default Some specs & Comparisons
2004 Mustang GT
Weight: 3113 lbs
Trans: 5-Speed Manual
Horsepower: 260 bhp @ 5250 rpm
Torque: 302 lb-ft @ 4000 rpm
Redline: 6000 rpm
0-60: 5.7 sec
Quarter: 14.1 sec @ 99 mph
Skidpad: .87g
Braking, 60-0: 120 ft
2003 Mustang Mach 1
Weight: 3420 lbs
Horsepower: 305 bhp @ 5800 rpm
Torque: 320 lb-ft @ 4200 rpm
Redline: 6250 rpm
0-60: 5.2 sec
Quarter: 14.0 sec @ 103 mph
Skidpad: .85g
Braking, 60-0: 122 ft
2005 Mustang GT
Weight: 3425 lbs
Trans: 5-Speed Manual/5-Speed Auto
Horsepower: 300 bhp @ 6000 rpm
Torque: 315 lb-ft @ 4500 rpm
Redline: 6250 rpm
0-60: 5.2 sec
Quarter: 13.9 sec @ 104 mph
Skidpad: .85g
Braking, 60-0: 116 ft
In brief, the 2005 Mustang GT will be heavier than the 2004's because of added safety equipment (to meet gov't standards) and larger size. However, the added horsepower still compensates for the additional weight making it faster in the 0-60 and quarter mile. The new GT is comparable to the Mach 1's as far as track times go. It is said the ride feels more "solid" than the 04's. Keep in mind, these were completely stock runs and the drivers capabilities, track conditions, etc. will affect times...
That's all I know...
ricekiller2003 is offline
Old 09-01-2004, 01:53 PM
TattooTears
TattooTears's Avatar
Default RE: Some specs & Comparisons
not bad at all, I just can't wait to see some on the showroom floor.
TattooTears is offline
Old 09-01-2004, 04:32 PM
matthockey32
I ♥ Acer
matthockey32's Avatar
where did you get those numbers? the v6 stangs weigh almost 3200 lbs and a GT weighs more than the v6.
matthockey32 is offline
Old 09-01-2004, 06:18 PM
ricekiller2003
ORIGINAL: matthockey32
fast-autos.net has all the specs posted. Curb weight may be different because 15.7 gallons of gas weighs alot!
Old 09-04-2004, 06:39 PM
04mustang
04mustang's Avatar
yeah i think the 04 weighs 3317
04mustang is offline
Old 09-11-2004, 04:22 PM
Stinger
Stinger's Avatar
If im not mistaken the 2004 weight is wrong, that is the v-6 you have there. 2004 GT was showing almost 3300 pounds.
Stinger is offline
Old 09-11-2004, 04:23 PM
Stinger
Stinger's Avatar
Also one other note i havent ever seen a stock GT run low 14s yet.. Seen alot and have alot on film.
Stinger is offline
Old 09-11-2004, 09:25 PM
Redline03GT
Redline03GT's Avatar
Ive seen a stock 99+ GT run a 14.0 and I KNOW that the Mach 1 can hit deep into the 13s. Thanks for the info though.
Redline03GT is offline
Old 09-11-2004, 10:50 PM
matthockey32
I ♥ Acer
a v6 weghs about 3300 lbs from factory, the GTs weigh about 250 lbs more. the 05 GTs are supposed to weigh within 100 lbs of the 04 GTs. and how is the mach1 so much heavier, there is not that much difference except in the engine.
Old 09-17-2004, 03:47 AM
kevin02
kevin02's Avatar
here is the problem i saw. the 03 mach 1 had more hp and tq and weighed less. so how is the 05 faster in the 1/4? i was just lookin at the comparisons
kevin02 is offline
Quick Reply: Some specs & Comparisons
