Clock changed to Daylight Savings by itself
#22
RE: Clock changed to Daylight Savings by itself
ORIGINAL: tritonpwrd
Mine changes automatically...but then again its aftermarket and uses the GPS sats to update the clock.
I dont think the stock radio changes by itself
#23
Same here...
My Stang didn't change the time... but it ran just FINE driving to work today, so there is no concern on my part.
My Garmin Nuvi 660 which I got for XMas didn't change the time... I had to go into the settings and click the "Daylight Savings Time" radio button. It was set to auto.. but didn't change by itself.
However - I went to the Garmin website and under support you will find they have a fix for that and several other things.
Now my Garmin is working perfectly!
Such is life.
Such is life.
#24
guys, guys, guys...it's this simple. by default, RDS comes switched off on our cars. you can switch it on by turning on the radio, holding menu for 5 seconds, then hitting seek > or <. once (if) you have RDS on, it will download song titles, radio station types, etc., as well as the time from neighboring radio stations.
so if you have it switched on, your clock will update. if you have it off, your clock will not auto-update. i bet 99% of stang owners never even heard of this feature!!! i just found out about it a few days ago, myself. really cool...you can search normal FM stations for those that play top-40, classical, country, etc. just like XM. it's a REALLY sweet feature. pretty sure you need your original antenna though...
also, not sure if it's shaker 1000 only, or shaker 500 too. but i suggest you try it...one benefit, is no changing your clock (provided your local radio stations are RDS enabled!)
#25
ORIGINAL: imyy4u
And Prof. Wizard, thanks for the tip about the Garmin update...I'll have to upload that into my unit tonight.
#26
ORIGINAL: Sprzout
I'm pretty sure the RDS option is only available on the Shaker radios, because I've been looking for it in the manual and on my radio (I bought the cheap radio, with the possible intention of replacing it with a better head unit) and it doesn't seem to be available. I'm going to try the "hold the menu button for 5 seconds" option tonight when I get home and see if I'm able to turn on the RDS option...
ORIGINAL: imyy4u
#27
Mine didn't change. Damn, I had to press the menu, go to the clock and press the hour arrow 1 time, Voila, set. Life is difficult but I struggle on.
LivingInThePast
09-16-2015 12:20 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-02-2015 08:40 PM
