Sponsored by:
Sponsored by:
First time oil change, what will I need ?
Old 03-27-2013, 02:10 PM
rm2092
rm2092's Avatar
Default First time oil change, what will I need ?
No this is not my first time changing oil in a car but my first time in my Mustang.
The reason I ask is all my other vehicles were trucks so I could just crawl under and change the oil with out any ramps or a jack and of coarse I own neither of them so ill need to barrow some from the neighbor down the street. So what will work best for my Mustang a ramp or find a floor jack ? I have like 7100 miles on my car so so I'm going with Amzoil because a freind of mine is a rep for them and I can get the oil and filter at cost.
rm2092 is offline
Old 03-27-2013, 05:18 PM
Nuke
Nuke's Avatar
I use ramps (Rhino Ramps; the silver ones) but whatever works for you.
I can't recall if the plug requires a 15mm or 14mm socket; I change oil on way too many vehicles. I also drape a plastic bag over the line (can't recall if it's for the AC or tranny...) that oil from the filter will sometimes drip on, possibly due to the angle of the car due to the ramps, so that any oil that gets on the bag will drip into the drain pan.
Also, expect the factory filter to be on VERY tight. I had to near-destroy the old filter with a large pair of jaw-type filter remover.
And other than rags and something to put the old oil in, it's pretty simple.
All of the above is on the 4.6L. I've never been under a 5.0...
Nuke is offline
Old 03-27-2013, 05:22 PM
dlazrael
dlazrael's Avatar
I didn't have the appropriate box wrench so I used a crescent adj... I also cheated and used a lift, but typically I use jacks and jackstands, I am always leery of the ramps cause I'm afraid I'll drive to far on em
dlazrael is offline
Old 03-27-2013, 06:44 PM
JK 23112
JK 23112's Avatar
I don't know if the newer Mustangs have this quirk, but the 1990s Mustang GT with the 5.0L V8 had TWO oil drain plugs. The oil pan was straddled over a crossmember.
JK 23112 is offline
Old 03-27-2013, 08:31 PM
Art161
Art161's Avatar
Do not use a jack to support the car while you are working under it. It is not stable enough. Use a lift, ramps, or jack stands.
Art161 is offline
Old 03-27-2013, 08:34 PM
dlazrael
dlazrael's Avatar
I said... jack and jack stands.... just saying
dlazrael is offline
Old 03-27-2013, 08:58 PM
FinallyHappy
FinallyHappy's Avatar
Nothing special is needed on the 5.0. I'd use ramps for the front and use jack stands on the rear. Like Nuke said...the factory filter will be VERY tight.
FinallyHappy is offline
Old 03-27-2013, 10:50 PM
3vStang
3vStang's Avatar
Follow this thread and youll be fine. https://mustangforums.com/forum/5-0l...-this-car.html
Kidding. Nukes right on.
Quick tip. Your going to have to partially drop the belly pan on the 2011+ to get to the filter, its just a couple small (8 or 10mm bolts)
3vStang is offline
Old 03-27-2013, 11:57 PM
Art161
Art161's Avatar
My comment was not directed to you. It was directed to OP, who was wondering whether to use a ramp or a floor jack.
Art161 is offline
Old 03-28-2013, 02:35 AM
Dragonetti
Dragonetti's Avatar
Need a container big enough to catch eight quarts of oil. Had about half a guart hit the floor before I got the plug in after realizing the oil wasn't going fit. Sounds like you got the rest covered.
Dragonetti is offline
Quick Reply: First time oil change, what will I need ?
