Sponsored by:
Sponsored by:
Steeda Ultralight lowering springs install (w/pics)
Old 04-18-2007, 11:18 PM
jettaflavor
I ♥ Acer
jettaflavor's Avatar
Default RE: Steeda Ultralight lowering springs install (w/pics)
Wow - that's hot. Thanks man, great write up!
jettaflavor is offline
Old 04-19-2007, 12:13 AM
Bretstang06
Bretstang06's Avatar
Great write up and pics. I'm going to be replacing my springs sometime in the next few months and will definitely be using this post as a reference. I just installed my Hurst shifter last weekend and jacked up the front of the car in the same locations you did and left the jack in place as an added safety measure. It is a little hairy at first crawling under the car but after a couple of minutes it's no sweat, just as long as an earthquake doesn't decide to rumble through SoCal when I'm under there.
Bretstang06 is offline
Old 04-19-2007, 01:39 AM
FordDude
FordDude's Avatar
Another great write up TacoBill. I don't suppose you made any measurements with the rear spring change? fd
FordDude is offline
Old 04-19-2007, 01:46 AM
TacoBill
TacoBill's Avatar
Thanks guys!
ORIGINAL: FordDude
The rear dropped 1".
If just installing the rear springs, it would just about level the car.
TacoBill is offline
Old 04-19-2007, 03:00 AM
FINGT
FINGT's Avatar
Good story with pics. Took some time to do it and take pictures while working on it.
And the car looks great now.
FINGT is offline
Old 04-19-2007, 04:06 PM
bchataroo
bchataroo's Avatar
TacoBill,
If only the manufacturers would make instructions like you do. Maybe you should inquire with them about selling these instructions? These instructions willgive a complete novice the ability to change springs on their own. I plan to use these to help me change my front struts out.
thanks a lot
bchataroo is offline
Old 04-19-2007, 05:01 PM
Kaldar142
Kaldar142's Avatar
ORIGINAL: bchataroo
TacoBill,
thanks a lot
+1 tacobill, you you seem to take the extra time and care with your instructions... in most cases, alot better then other 'official' instructions lol
Kaldar142 is offline
Old 04-19-2007, 05:19 PM
TacoBill
TacoBill's Avatar
Appreciate the kind comments, guys.
If I save just one guy from taking his car into the shop by doing the drop (or any other mod I've posted) themselves, it's worth it to me.
Think about it, not only will you save some major $$$ on labor, but no one will take the time and care on your car as you will.
TacoBill is offline
Old 04-19-2007, 06:59 PM
tritonpwrd
tritonpwrd's Avatar
TacoBill,
Thanks again for the great post.
Just have a question about the pinion angle. I'm gonna be putting these springs on over the weekend and was wondering if they throw the pinion angle off by alot? I ordered the adj. upper control arm to correct this but it on backorder from BMR for another week. Would I be safe in lowering the car without correcting the pinion angle using these springs?
Thanks
tritonpwrd is offline
Old 04-19-2007, 07:21 PM
TacoBill
TacoBill's Avatar
ORIGINAL: tritonpwrd
Thanks
Yes, as long as you haven't installed a 1 piece driveshaft yet. If so, you'll need the adjustable UCA's.
TacoBill is offline
Quick Reply: Steeda Ultralight lowering springs install (w/pics)
