Sponsored by:
Sponsored by:
Vibration at 3250 rpms......
Old 07-26-2007, 08:25 PM
  #21
hammeron
hammeron's Avatar
Default RE: Vibration at 3250 rpms......
ok, gotcha.....i must have missed the nuetral test, result memo
ORIGINAL: moosestang
No I didn't, because the vibe is definately there when reving in nuetral and of course the driveshaft and rear wheels aren't moving then.
hammeron is offline
Old 07-26-2007, 08:30 PM
  #22
hammeron
hammeron's Avatar
alright, i'm ready to make a prediction:
crankshaft pulley out of balance.
i'd like to see some more predictions, just to make it
interesting.....
hammeron is offline
Old 07-26-2007, 09:35 PM
  #23
vb101
vb101's Avatar
I have the same vibration just at a different rpm. Mine is at around 1175 rpms & 2375 rpms. Since it occurs a specific rpms and is at multiples of the low rpm then it's a harmonic vibration. The engine has a normal harmonic vibration that with the stock motor mounts should not be very noticeable. Our engines are internally balanced. I remember reading that there are some sort of balancing rods in the engine. My theory is it's either the engine is not properly balanced or the clutch/flywheel assembly is not properly balanced. I'm leaning more toward the engine not being properly balanced. At some point in the future when I get some bills paid off I plan on having my engine completely rebuilt from the ground up with all forged internals and get the engine properly balanced at that time. There is a shop near where I live that can do engine balancing. Personally I hope it's the clutch/flywheel, that's easier and cheaper to fix. Even if it's the engine not being properly balanced it shouldn't damage anything in the short term. I have 34,000 miles on mine and it runs as strong as the day I got it and nothing has broken yet. I'm rather hard on my also.
vb101 is offline
mtgldr
02-03-2024 09:00 PM
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
Lethaldosage423
10-19-2015 12:12 AM
mdj89
09-23-2015 08:49 AM
Quick Reply: Vibration at 3250 rpms......
