passenger turn signal acting weird - HELP!
I just installed my fog lights and after i did i noticed that my passenger side marker has been acting weird. It doesn't come on when i turn on the headlights or the running lights but it works when i engage the hazard button and it also works when iusethe turnsignal. What is the deal? is it a blown fuse? i looked in the manual and it seems as though there are no fuses for the lights.
any help would be greatly appreciated! thanks guys
RE: passenger turn signal acting weird - HELP!
Did you do some wiring? If so time to go check what you did. Did it work beofrre you did the lights?
If you did no wiring then you may have an issue with the Smart Box which will require a trip to the dealer to be fixed.
Richard
Richard
well i wired the fogs with a pretty standardharness, the only thing i had to tap into was one headlight wire and i just grounded it to the frame asusual.
what does the smartbox do? will ford replace the whole thing or will they just flash it or something?
It's not going to be a bulb if it works when the hazards are on. Like i said you have either messed something up with your splicing or there is an issue with the Smart Box. The Smart Box is inside the cab of the car and if it is bad will have to be replaced and the new one will have to be programmed. Also since you spliced wiring Ford could very well blame the problem on that, and will most likely try.
Richard
Richard
ORIGINAL: 06GT4RAD
It's not going to be a bulb if it works when the hazards are on. Richard
Headlights or running lights are the dim
lamp and the turn is the bright lamp.
Hazzards = bright lamp
Turn = bright lamp
Clearance or running = dim lamp.
Seems simple. Burned out dim.
The hazzards are the bright lamps
in the rear and front? Hazzards work =
bright lamp works.
No running = burned out dim bulb.
Pull that sucka outta there and check it
or replace it and see whats yous gots before
heading to the stealership unless you have
$$ growing on a tree somewhere.
ORIGINAL: 157db
Are hazzards the same as turn signal.
Turn = bright lamp
bright lamp works.
ORIGINAL: 06GT4RAD
Turn = bright lamp
bright lamp works.
Richard
I know what your problem is. Well the whole foglight wiring you did is wrong. I bet you mess around with the healights and it's being weaken because it doesn't have a relay which needs one. It turns on and then turns off after a while. I've been messing around with the box and you have to becareful but you haven't done any damage, just yet. Anyways try getting a new harness to work the folights. These are worth your money because I have 4 foglights and they work great. http://cgi.ebay.com/ebaymotors/05-06...spagenameZWDVW
I'm about to do my next upgrade which is a backup sensor (last time I back up fast, stupid supercharger,I hit a car in the parking lot which I had to get a new bumper lol ) Now I have to play around with the taillights. Goodluck.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
09-08-2015 11:50 AM
zanemoseley
09-06-2015 12:58 PM
