door rattling
door rattling
i have the shaker 500 in my car which really aint bad. but if i turn up the volume to about under half the right door sub sounds like it isshaking inside the door. or there maybe a screw in the door. i really dont know. it happens everytime the bass hits. any ideas how to fix so i can enjoy my music again. do u think since its under warranty they will fix it?
RE: door rattling
Me too ... very annoying and I did line with Dynomat. What was cool was that when I first got my car back from the body shop with a new door ... the rattles were gone. However ... the first time I turned up that base they started again .... [:@]
RE: door rattling
Same problem here. I think it's actually the switchplate for your window controls that is rattling, not the sub. try pinching it down next time and seeing if that lessens the problem. Switchplate rattle is fairly common, I think someone before solved it with some dynamat under the plate. Use the search function and your question should be solved
RE: door rattling
It's not that, mine does the same thing look behind the door handel that you pull to open the door there's a cheep little plastic plate back there that makes noise when you turn thevol. up. it took me a few weeks to figure it out when you turn thevol. up and start to hear it buzz and make noise put you finger on that plate and see if the noise stops. I'm pretty sure you are haveing the same problem as me.
09-25-2015 06:58 PM
