Sponsored by:
Sponsored by:
Camber bolts vs. camber plates
Old 11-20-2007, 12:30 AM
slvrstang2007
slvrstang2007's Avatar
Default Camber bolts vs. camber plates
Just curious why it would be better to have new camber plates when doing suspension work vs. just getting some camber bolts which are much much cheaper?
slvrstang2007 is offline
Old 11-20-2007, 10:45 AM
slvrstang2007
Default RE: Camber bolts vs. camber plates
bump
Old 11-20-2007, 11:06 AM
RodeoFlyer
RodeoFlyer's Avatar
range of adjustment
if your not racing and dont need more than 2 degrees they're not necessary
RodeoFlyer is offline
Old 11-20-2007, 11:52 AM
Argonaut
Argonaut's Avatar
I read that camber bolts can "slip" under extreme use...that probably means racing. But, look at an aftermarket camber plate compared to the stock setup. Obvious differences, over time the camber plate is going to remain much more solid and stable. I guess it all depends on your plans for the car.
Argonaut is offline
Old 11-20-2007, 12:04 PM
SlideWRX
SlideWRX's Avatar
Plenty of auto-crossers & trackday drivers use camber bolts, they should be fine. Camber plates are great for adjustability, in that one can drive to the event, adjust the plates fairly easily and run the event, then adjust them back for street use.
SlideWRX is offline
JRT1
JRT1's Avatar
ORIGINAL: RodeoFlyer
range of adjustment
Hey Chief,
Could you elborate a little on this for us please?
I am in the process of getting my parts for my suspension and I have BMR camber bolts with new factory strut caps.
I have been considering the Steeda camber plates for my D-Specs though.
In the spring I am planning on getting into some Auto-X and was wonder why would I need more camber adjustment for that?
Care to do some educating?
Thank you sir.
JRT1 is offline
Old 11-20-2007, 06:22 PM
RodeoFlyer
RodeoFlyer's Avatar
I'm hoping F1Fan will step in here. I can give you the meat and potatoes explanation but he will get into detail that i'm too lazy to.
Old 11-20-2007, 06:32 PM
06tyrfryr
06tyrfryr's Avatar
with the camber bolts you are limited to adjusting onlycamber at the knuckle, with the caster camber plates you can adjust the caster and camber
06tyrfryr is offline
Old 11-20-2007, 07:24 PM
slvrstang2007
So for some1 who just wants better handling on the street and isnt planning to do any auto cross camber bolts are the way to go?
Old 11-21-2007, 06:15 AM
redxls
redxls's Avatar
some of the caster/camber plates are also new upper strut mounts that will eliminate the popping sound of the factory plastic piece. I decided to spend the extra cash and get new plates.
redxls is offline
Quick Reply: Camber bolts vs. camber plates
