Sponsored by:
Sponsored by:
rwhp with HO whipple?
Old 12-22-2007, 11:26 PM
07mustanggt
07mustanggt's Avatar
Default rwhp with HO whipple?
Kit should be on in the next few weeks and was just wondering what rwhp I should be putting down with the 10psi pulley?
07mustanggt is offline
Old 12-22-2007, 11:31 PM
MexGT
MexGT's Avatar
Default RE: rwhp with HO whipple?
Around 450rwhp, but theres never enough rwhp !
MexGT is offline
Old 12-22-2007, 11:32 PM
Pwny
Pwny's Avatar
450-460
Pwny is offline
Old 12-22-2007, 11:35 PM
07mustanggt
I've seen it from 440-475, could this be the tune, thealtitude, temp., or what?
Old 12-23-2007, 12:04 AM
meekstro
meekstro's Avatar
Be careful getting caught up in the numbers. There are many variables. Like these different style dynos. A car my make 450 on a dyno jet but may only be 405 on a dyno dynamics.
meekstro is offline
Old 12-23-2007, 07:26 AM
Blackhawk
Blackhawk's Avatar
I think that's about the limit for what you want to put out on a stock GT motor anyway, so what's it matter?
Blackhawk is offline
Old 12-23-2007, 09:01 AM
marcuskeeler
marcuskeeler's Avatar
You can push the motor past the limit withthis setup, so do yourself a favor and get it tuned properly. Any canned tune you get will be fine until you get to a dyno tuner but i wouldn't want to wail on the motor using it.
marcuskeeler is offline
Old 12-23-2007, 09:07 AM
Blackhawk
Blackhawk's Avatar
You can run higher hp than normal limits with the Whipple than another forced induction set-up?
Old 12-23-2007, 09:24 AM
Boozshey
Boozshey's Avatar
Yup, they only number to get caught up in is the Boost. 10lbs is safe. Get what you can out of that and then tame it down a bit. All cars will be a little different as will the tunes. But it's upping the boost where you get into a lot of trouble. There was a post about it awhile ago that explained it all...
Boozshey is offline
Old 12-23-2007, 09:36 AM
hammeron
hammeron's Avatar
let us know how you like it, after the first
test drive
hammeron is offline
Quick Reply: rwhp with HO whipple?
