Sponsored by:
Sponsored by:
Supporting mods for Nitrous
Old 01-10-2008, 04:30 PM
banka87
banka87's Avatar
Default Supporting mods for Nitrous
Do you guys think any are really needed?
I'm surean aluminum DS and a LSD would help, but I don't think they're crucial.
Anyone have any input?
banka87 is offline
Old 01-10-2008, 07:35 PM
banka87
banka87's Avatar
Default RE: Supporting mods for Nitrous
No one?
banka87 is offline
Old 01-10-2008, 07:39 PM
06elnr
06elnr's Avatar
none are really needed unless you get over 125 shot, except colder plugs and a tune to pull out some timing.
06elnr is offline
Old 01-11-2008, 10:28 AM
D_Gusler
D_Gusler's Avatar
^^^agreed. How big of a shot are you running, and what gears do you intend to spray in?
D_Gusler is offline
Old 01-11-2008, 10:44 AM
probinator
probinator's Avatar
over a 75 You need colder plugs. Over a 125 shot I reccomend a BAP. Some have done the 150 without it but to be safe I would use one.
Also a bottle heater and use nitrous with pressure 900Psi or more.
If you have a tune.I reccomend you take out timing when squeezing a 100 and over. I ran a 100 shot on the 89 tune with -2* timing on 91 gas.
I run a 125 on a 87 brenspeed tune with 91 gas with -4* timing throughout the powerband. I just havent dynoed it yet on the 125
probinator is offline
Old 01-11-2008, 10:45 AM
stiggy
stiggy's Avatar
75shot and you need nothing. 100shot and you need to go retarted like 1 degree just to be safe 125+ you need colder plugs b/c anything over 100 melts them and even more timing retearted.
stiggy is offline
Old 01-11-2008, 11:52 AM
banka87
banka87's Avatar
I was planning on getting colder plugs and a tune from Brenspeed, until I get around to a dyno tune. I'll probably be running a 75-100 shot most of the time. 125 is the highest I'll go, and that will be mabey once or twice when I'm trying to pull some low numbers.
I planned on buying the kit that comes with the heater, remote opener, blowdown tube, and the purge kit. I think I should be able to do some damage with that
banka87 is offline
Old 01-11-2008, 01:11 PM
Mpaint99
Mpaint99's Avatar
Get colder plugs, and a dyno tune. Dont run a generic tune.
Mpaint99 is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
TimeLord101
10-01-2015 06:40 AM
Quick Reply: Supporting mods for Nitrous
