Sponsored by:
Sponsored by:
Plugs keep fouling out. Think I found out the solution
Old 01-18-2008, 02:24 PM
  #31
Dex
Dex's Avatar
Default RE: Plugs keep fouling out. Need some help
melt them at idle though? the car doesnt even stay running
Dex is offline
Old 01-18-2008, 02:25 PM
  #32
LTMGlobal
Banned
LTMGlobal's Avatar
ORIGINAL: Dex
ORIGINAL: LTMGlobal
So this is all happening during intitial startup after having the motor apart and replacing internal parts?
Has the engine run long enough for you to properly heat cycle it?
Yes
Nope
Hoping its a ground problem because then that will be easy haha the car is CURSED!
You're playing with fire IMO - get the problem figured out before running it - you want to be on the rich side when doing the initial startup. As bad as running lean is in general it is much worse to do so whengetting those new parts broken in.
Find a shop in your area to help you out if you need to!
LTMGlobal is offline
Old 01-18-2008, 02:35 PM
  #33
Dex
Dex's Avatar
there is one shop in utah. dont know much about them because everyone does work themselves. I'll take it by though...now how should i get it on a trailer?
Dex is offline
Old 01-18-2008, 02:48 PM
  #34
GidyupGo
GidyupGo's Avatar
Uhaul recomends that you use boards to help raise the front end when loading on their trailors.
GidyupGo is offline
Old 01-18-2008, 02:54 PM
  #35
moosestang
moosestang's Avatar
ORIGINAL: Mpaint99
I dont what Mod's you have. But your air fuel mixture should be in the 12's to be running safe. At 15 or 16 your running so lean your going to melt your plugs. Your air fuel mixture shouldn't spike at high RPM's if it's tuned properly.
He's refering to the air/fuel at idle.
moosestang is offline
Old 01-18-2008, 03:02 PM
  #36
Dex
Dex's Avatar
ORIGINAL: GidyupGo
the car doesnt run...
Dex is offline
Old 01-18-2008, 03:24 PM
  #37
LTMGlobal
Banned
LTMGlobal's Avatar
Buy or rent a come-a-along
or just have it towed
Old 01-18-2008, 03:28 PM
  #38
Dex
Dex's Avatar
more bling bling
Dex is offline
Old 01-18-2008, 04:10 PM
  #39
GidyupGo
GidyupGo's Avatar
ORIGINAL: Dex
ORIGINAL: GidyupGo
Flat bed and about $150.
GidyupGo is offline
Old 01-18-2008, 05:15 PM
  #40
dieselboy28
dieselboy28's Avatar
hey dex what altitude is your tune set for?
really sounds like the tune isnt callin for enough fuel or your fuel system is messed up. shouldnt run too lean at idle. you sure you have the mafia set right? i would make em givve you a new tune then go from there.
dieselboy28 is offline
Quick Reply: Plugs keep fouling out. Think I found out the solution
