Sponsored by:
Sponsored by:
Brights and fogs at the same time
Old 01-28-2008, 03:33 PM
  #21
schapman
schapman's Avatar
Default RE: Brights and fogs at the same time
please try turning your fogs on in your garage. They dont just shine down...they will light up the wall higher than the headlights.
ORIGINAL: GidyupGo
ORIGINAL: rshamekh
The problem with fogs is that they shed light in almost every direction.
The headlights are directed downwards towards the road, that's why the fogs are annoying at night.
No they don't. Turn yours on and off at night and you will see they're limitations. 30 feet at most and down too.
schapman is offline
Old 01-28-2008, 03:40 PM
  #22
presto
presto's Avatar
ORIGINAL: schapman
the same statapplies to people that drive at the speed limit or under it. Theyget in lessaccident. Do you follow that one to?You dont have to get personal and call people names either.
ORIGINAL: Burnsy
you're a big *** nuke[8D]
but legit i drive with my fogs on 24/7.... i read some stat that said ppl who drive with lights on during day are some amount less likely to get in an accident, and that was enough justification for me, plus i like my fogs
smiley's indicated joking, perhaps?
presto is offline
  #23
TerpsandStangs
TerpsandStangs's Avatar
Just a point of clarification...aren't fog lamps supposed to be located as close to the ground as possible, for example not on the same level as the normal headlamps? To me these seem more like driving lights that may need to be adjusted on a case by case basis because it seems that some tend to point straight ahead or even upwards slightly.
That being said I drive with mine on at night (because it does look badass) but I have checked to make sure they do not aim into oncoming drivers' eyes and I have only been flashed once or twice.
TerpsandStangs is offline
Old 01-28-2008, 03:42 PM
  #24
Nuke
Nuke's Avatar
ORIGINAL: schapman
ORIGINAL: Burnsy
Schapman, I appreciate the support but Burnsy's ok. And as far as this topic is concerned, I need more buttered popcorn...
Nuke is offline
Old 01-28-2008, 03:44 PM
  #25
GidyupGo
GidyupGo's Avatar
ORIGINAL: schapman
ORIGINAL: GidyupGo
ORIGINAL: rshamekh
No need to. I can do the test in actual driving situations. You can tell where the main body of light is going.
GidyupGo is offline
Old 01-28-2008, 04:25 PM
  #26
157dB
Cut & Paste Expert
157dB's Avatar
Here is the aftermarket wiring
[IMG]local://upfiles/69445/46B83941CA724CAC9B83ABC2017DD63D.jpg[/IMG]
157dB is offline
Old 01-28-2008, 04:28 PM
  #27
157dB
Cut & Paste Expert
157dB's Avatar
And here
[IMG]local://upfiles/69445/7F49123EC43846A6A98126249C9851A7.jpg[/IMG]
157dB is offline
Old 01-28-2008, 04:29 PM
  #28
GidyupGo
GidyupGo's Avatar
ORIGINAL: 157db
Where? The wiring I got consisted of a relay, a ground, a hot to the fuse block, 1 to the headlight wire, and 1 to the fog light wire.
GidyupGo is offline
Old 01-28-2008, 04:45 PM
  #29
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: GidyupGo
ORIGINAL: 157db
Its not a kit. The diagram is all you need along with 2 relays, not just one.
W is the 12 tap in the power distribution box under the hood.
X is for the fod indicator on the GT headlight switch.
Y is ground to turn on the fog relay.
Z is hooked to the high beam wire.
Flash to pass =s fogs and high beams.
High beams on =s fogs on, regardless of fog switch position.
157dB is offline
Old 01-28-2008, 04:51 PM
  #30
300GT
300GT's Avatar
ORIGINAL: Burnsy
plus the cars looks 50x better with all 4 on.....badass
+1. I always run with all four lights on, day or night. Ifmy driving lights are "blinding" anyone, then those people need to be systematically removed from the gene pool, IMO.
300GT is offline
Quick Reply: Brights and fogs at the same time
