Engine Start Button
Engine Start Button
I know this has been posted before and I did use the search function multiple times. I did not find the specifics I was looking for. I am about to order the S2000 engine start button off ebay. What else do I need to install? Just a fuse wire from autozone? I am looking for instructions on a self install for the S2000 button configuration. Thanks is advance guys!
RE: Engine Start Button
Yes, the key does have to be placed in the key ignition and turned to the "on" position in order for the Push Button Start to turn the vehicle on. Its primarily a security feature preventing the car from starting solely with the button and no key. Depending on how you set up the wiring, you can wire the push button so that it is the only method of ignition or so that both the key and push button may start the car.
ORIGINAL: justang07
i thought about this mod a few times but u still have to put the key in and turn like halfway. so its kinda pointless. correct me if im wrong. but i do like it tho.
How hard is it to install? Like less than 1 hour? I have been looking at it. And I agree, the power plug was a bad decision to put it on top of the stereo.
[IMG]local://upfiles/90468/4608CBA6874F47EA910C451BAF0AAB67.jpg[/IMG]
