Sponsored by:
Sponsored by:
Remote Start / Engine Shutoff
Old 04-12-2005, 03:52 PM
StupidTodd
StupidTodd's Avatar
Default Remote Start / Engine Shutoff
The new mustangs have the engines that's specifically coded to the key right?
So, without the key in place, the motor won't start... can you still install a remote start kit on it? or does this not work because of the anti theft feature?
and if you can install a kit, any recomendations?
StupidTodd is offline
Old 04-14-2005, 08:03 PM
First GT
First GT's Avatar
Default RE: Remote Start / Engine Shutoff
My brother's Acura has the same thing with the key. He installed a remote start in his car. He had to hide the valet key somewhere in the car close enough that the remote start transponder would read it and it starts up fine. Kind of an extra pain in the a$$, but I'm sure the same type of workaround will work in your stang.
First GT is offline
Old 04-14-2005, 08:18 PM
Professor Wizard
MF Moderator
Professor Wizard's Avatar
Good question...
I don't know .. but Remote Start IS a Ford Factory option you can purchase, and the dealership indicates NO PROBLEM with getting it... I have Remote start added to my car on order.
Professor Wizard is offline
Old 04-15-2005, 05:32 PM
cheysdaddy
cheysdaddy's Avatar
I had to have the same thing installed on my wife's mini van. It's just a little box that you program with your key codes and it sends out a signal. As far as getting one from Ford you might shop around cause they used to be about twice as much as after-market and the after-market works just fine.
cheysdaddy is offline
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
movielover40
08-27-2015 10:13 PM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: Remote Start / Engine Shutoff
