Sponsored by:
Sponsored by:
Hood paint bubble (rust) TSB?
Old 05-01-2008, 11:44 AM
  #31
timothyrw
timothyrw's Avatar
Default RE: Hood paint bubble (rust) TSB?
quick internet research indicates that the 99 cobra recall was a voluntary recall by ford after blueovalnews.com and car and driver first reportedthe power deficit.
no mention of a federal lawsuit or "order" is ever mentioned.
this would be a civil issue between the manufacturer and the consumer.
anyway, i had the corrosion problem on my 2003 explorer. dealership fixed it no questions asked. did a great job, too!
ORIGINAL: americaniron
It's true that almost every recall is for saftey issues, there have been recalls for non saftey problems. The 99 Cobra is an example.The Feds ordered it recalled by court order because it did not meet the advertized H P output. Owners filed a lawsuit and won.Ford had to rework the intake, and exhaust so that it would make the320 hp itclaimed to have.That was for all owners of that year. Even so this hood corrosion problem will never make that kind of status.
timothyrw is offline
Old 05-01-2008, 11:51 AM
  #32
loaded6shooter
loaded6shooter's Avatar
picking mine up today after getting my hood resprayed, and im out of warranty....of course i didnt mention it to them but none he less i get it resprayed and my stripes replaced for free
loaded6shooter is offline
Old 05-01-2008, 11:56 AM
  #33
richmod
richmod's Avatar
ORIGINAL: loaded6shooter
hmmm..wonder if my clear bra would also be replaced free?
richmod is offline
Old 05-01-2008, 12:00 PM
  #34
richmod
richmod's Avatar
The TSB says it is due to iron contamination. So technically it's not rust.
richmod is offline
Old 05-01-2008, 02:39 PM
  #35
07 Stang
07 Stang's Avatar
ORIGINAL: Kara
I just looked at mine and didnt see any bubbling. Just some chips right there[:@]
Kara, did you check under your hood? That's where the problem starts.
07 Stang is offline
Old 06-20-2014, 08:32 AM
  #36
jaskyland
jaskyland's Avatar
Originally Posted by raubt
So I've sadly realized that the paint on the front edge of the hood on my '06 is bubbling, and I'm gonna have to get that repainted or whatever (which sucks, because I wanted to keep a high-impact area for rocks like the hood in factory paint, but what do you do.)
Anyway, I'm gonna go roll by Ford tomorrow and talk to the bodyshop guy, and I was wondering if any of you have a link to the TSB for the hood paint bubbling. Bodyshop guy will probably know what I'm referring to, but I'd like to have a printout with me just in case he hasn't seen any instances of this before.
I checked through the TSBs listed in the S197 FAQ quickly, but I didn't see it in there.
Any help? Thanks.
Go to fordtechservicebulletins/hoodcorrosion. It will bring up the info for you.
jaskyland is offline
Old 06-20-2014, 08:35 AM
  #37
jaskyland
jaskyland's Avatar
You should have made them replace the hood. It may come back if they used the same hood. It's from iron contamination from the factory on the aluminum hoods. I had mine re3placed and painted. The Ford dealership that I was working at at the time fixed mine under warranty and mine was well out of warranty. Good luck with yours.
Old 07-03-2014, 11:06 AM
  #38
Criticalmass
Criticalmass's Avatar
Originally Posted by Kara
Wait was there a recall for this? Or is it just under your warranty?
Recalls are for Safety issues. Technical Service Bulletins is where this would fall under.
Criticalmass is offline
Old 07-03-2014, 12:51 PM
  #39
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Late to the party but I had the same problem on my '11.
Had to have Ford strip and repaint it.
Matthew
Matt's 95 Stang is offline
Old 07-03-2014, 07:07 PM
  #40
DRAGUL
DRAGUL's Avatar
I would say this has probably been resolved after 6 years.
DRAGUL is offline
Quick Reply: Hood paint bubble (rust) TSB?
