Sponsored by:
Sponsored by:
Old 10-20-2015, 10:20 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
changing brake pads
Old 11-02-2008, 08:39 AM
Va. Stang
Va. Stang's Avatar
Originally Posted by miloman
Is this tool really necessary? I mean, I've always used a adjustable c-clamp and a small piece of .80 aluminum (to protect the piston from the clamp). Basically, your tool is pushing the piston in, the c-clamp works on the opposite side and pulls it in. Although the tool seems usefull, IMHO, it's money that could be spent eslewhere.
On some yes. I was unable to get my calp. to compress without it while turning them!
Va. Stang is offline
Old 11-02-2008, 10:10 AM
miloman
miloman's Avatar
Turning them? As if they screw in? If they screw in, they would have to screw out. I can't see the pistons doing all this screwing when we hit our brake pedals. Sounds like that could be referenced in another way, with all the screwing going on here, LOL. I'm confused.
miloman is offline
Old 11-02-2008, 11:55 AM
Stoenr
Stoenr's Avatar
Lol. Quit screwing around!
but ok, dont believe me.
Stoenr is offline
Old 11-02-2008, 01:26 PM
pascal
S197 Section Modder-ator
pascal's Avatar
I could have wrote that lol.
pascal is offline
Old 11-03-2008, 11:19 AM
SCCAGT
SCCAGT's Avatar
Yes, the rear calipers need to be screwed. LOL
If you really want to cheap out, you can use some needle nose pliers by sticking them into the slots and turn it that way. Look on the caliper for an arrow, turn the piston in that direction. I havent looked at mine, so I dont know if its there, but on another Ford we did rear brakes on last week, the pistons turned different directions on either side of the car and had an arrow illustrating the correct direction.
SCCAGT is offline
Old 11-03-2008, 01:04 PM
Argonaut
Argonaut's Avatar
On the S197 you turn the piston clockwise on both sides. I've heard of the pliers trick before - those that say it can be done and those that say it can't. On my car there is no way you could do that, its an absolute bitch to screw in. I've changed pads at least 10 times (road racing). As stated previously - save yourself the headache and just rent the disk brake tool kit from AutoZone, etc.
Argonaut is offline
Old 11-03-2008, 01:31 PM
SirKnightTG
SirKnightTG's Avatar
You obviously have never done rear brakes on these cars. LOL
It's a big PITA without the tool.
I did it without the tool (I have it now) and man it sucked. Took two people to do it and even then was hard because you have to clamp down and turn at the SAME TIME. So unless you have the tool or four arms, you'll need two people. One operating the c-clamp constantly turning on it and the other using needle nose pliers turning at the same time.
If you don't have the tool, don't do it. I learned my lesson.
SirKnightTG is offline
Old 11-03-2008, 06:05 PM
miloman
miloman's Avatar
Well, alrightee. I guess I'll have to go to Autozone when I put my slotted rotors and Hawk pads on.
Just doesn't make sense, stupid spark plugs, stupid rear brakes......WTF is Ford doing to us? Wait, the answer could be screwing us! LOL.
How does this stupid tool cost? Do companies, other than Ford, sell them? Maybe snap-on?
miloman is offline
Old 11-03-2008, 06:31 PM
Lethaldosage423
Lethaldosage423's Avatar
If there is a Snap on one...im getting it lol
We just got 15,000 dollars worth of snap on tools at auto shop at my school and when i go to UTI, they only use snapon and i will get a 50% discount lol!!
What does this tool cost?
Lethaldosage423 is offline
Old 11-03-2008, 06:34 PM
Stoenr
Stoenr's Avatar
Snap has it. I bought the tool used from our tool guy, but a matco set. I think my neighbor still has it too, hmm.
Stoenr is offline
Quick Reply: changing brake pads
