Sponsored by:
Sponsored by:
Ford 6.8L 3V truck engine in a 2005+ Mustang GT?
Old 11-22-2008, 01:41 AM
Riptide
Riptide's Avatar
Would the car not be a nose heavy pig?
Riptide is offline
Old 11-22-2008, 03:29 AM
howarmat
s197 Junkie
howarmat's Avatar
Hey cort, you might pm rygenstormlocke if you are thinking of using the sixxer shell. He has a little experience in that area. I am sure with money and time you can do it. It would be quite interesting too! Good luck and tell us what you find out bud!
howarmat is offline
Old 11-22-2008, 05:08 AM
robsimp
robsimp's Avatar
this build would be sick.. let us know what you plan on doing....
robsimp is offline
Old 11-22-2008, 10:01 AM
severnrc
severnrc's Avatar
probably...although I could spend some $$ on some carbon fiber parts (hood, driveshaft, front fascia...cause the v6 will need it) to help out a bit
I really need to get an estimate on the weight of it though...the GT500 setup is over 800 lbs, so that would be something to compare to
http://www.fordracingparts.com/parts...tKeyField=9560
severnrc is offline
Old 11-22-2008, 10:11 AM
severnrc
severnrc's Avatar
Thanks for the info and encouragement Matt, i'll do that.
severnrc is offline
Old 11-22-2008, 10:16 AM
howarmat
s197 Junkie
howarmat's Avatar
I also found this when looking around
http://www.moddedmustangs.com/forums...ustang-gt.html
I would say it has some good info....it is quite a bit longer it appears so it will require some work to get her in there.
howarmat is offline
Old 11-22-2008, 10:19 AM
pascal
S197 Section Modder-ator
pascal's Avatar
Originally Posted by Xeno
in 2007, i believe ford began making the gt chassis and the v6 chassis exactly the same as the gt500's, support/stiffness wise (which is stiffer/stronger than the pre-'07 models); the v6 and gt chassis might have been the same before '07 too, though
Nope.
First off, to avoid confusion, our cars are unibodies (I'm sure you know this)...
They have frame rails that are interrupted under the front seats roughly.
All body shells from 05 to now, are identical.
The Cobra has a HD crossmember to support the 5.4 set up.
All the sheet metal is the same, only the bolt on stuff changes from car to car.
Of course, convertibles are reinforced over a coupe to make up for the roof strength that is no longer there.
pascal is offline
Old 11-22-2008, 10:23 AM
severnrc
severnrc's Avatar
That info seems promising to go with a v6 chassis...is there an internet source (reliable) you can point me to for that information?
severnrc is offline
Old 11-22-2008, 10:29 AM
pascal
pascal's Avatar
Take you time reading as much as you can...
Once you start a project, a lot of money will be wasted if you quit.
A Terminator mill would be a good way to go, at very little extra weight.
I haven't seen that Combo on a S197 yet.
Maybe I'll do that, lol.
I have been interested in a carbureted stroked Windsor to put in a S197.
Haven't found a wrecked sixxer cheap enough yet...
pascal is offline
Old 11-22-2008, 10:34 AM
pascal
pascal's Avatar
QUOTE]
Not really, since I haven't regurgitated that thought yet.
I have other project to finish up first, before I get serious about that.
pascal is offline
Quick Reply: Ford 6.8L 3V truck engine in a 2005+ Mustang GT?
