Cam's and "Lopey" idle.
I ran a friends 2006 GTO when I had 3.55 gears and stock cams. all the same mods in my sig.
We both roooolled off the line real slow and hit it. We both hit second gear at the same time and started to wind it out. Halfway through second gear my car fell flat on it's face at 5500 rpm. We're neck and neck looking at each other and my friend gets a huge grin because he knew I was out of powerband. he pulled ahead, hit third and gained a car length on me.. end of race....
With my cams and gearing now... bye bye LS2 GTO . Lost contact with him and haven't had a rematch... yet.
Cost/install/tuning/pain and SUFFERING. All these things will be involved. Get ready. It will be worth it in the end but man...
Figure $700 for the cams, $500 for installation, and another ~$500 for a "dyno" tune which is a NECESSITY.
Then you're going to have to relearn how to drive your car because the powerband is going to be higher up.
And 4.10 gearing is also required to get the car moving with the lopey idle.
With all the right "pieces" it's heaven but if you leave anything out it will be hell.
I wouldn't touch aftermarket cams with a ten-foot pole unless you have:
1. 4.10 gears and/or a stall converter with automatic trans
2. $2000 and the time for custom dyno tuning
this is my honest opinion.
Futhermore, if I ever want to sell my car, the stock cams will have to be reinstalled because no one will want a late-model "hot rod"
If you have ever been close to a dragster, you can hear the lope during the idle.
Here is mine.
http://www.youtube.com/watch?v=1S7GfbipgsY
Here is mine.
each other also adds to the lopey sound.
The exhaust valve stays open longer to expell
more burned gasses and the intake valve opens
sooner to allow more fuel to flow into the cylinder
with a scavenging effect from the exhaust gasses
that are exiting at the same time. Vroooommmm.
Performance and a nice sound at idle.
The more the intake and exhaust lobes overlap
