Sponsored by:
Sponsored by:
Oil change
Old 01-21-2009, 05:03 PM
Goldenpony
Goldenpony's Avatar
Default Oil
Oil is the one thing you don't want to cheap out on. Amsoil if you want the best. Mobil 1 or Pennzoil are next best. I use Amsoil 0W20, Amsoil filter and change it 10K-15K miles. Just be sure to stay with synthetic.
Goldenpony is offline
Old 01-21-2009, 07:58 PM
07musclemustang
07musclemustang's Avatar
wow ok im going against everyone else but i would go standard ford 5-20 and ford filter for this change only. this allows the motor a little extra time to break in. be sure youve done alot of high rpm driving before you switch to full synthetic. the motor needs to break in.
after this change i would go full synthetic mobil 1 and ford filter... JMO but i didnt switch to synthetic in my beast untill 10k kms
07musclemustang is offline
Old 01-22-2009, 05:17 AM
mds08
mds08's Avatar
Mobil 1 is not even close to Amsoil. Royal Purple is better than Mobil 1 if you want to use that.
mds08 is offline
Old 01-22-2009, 05:59 PM
07musclemustang
omg not this again. run what ever freakin oil you want.
IMO
1 redline
2 tied between mobile 1 and amsoil
3 way way down there is RP. it better for gears/ trans again IMO
Old 01-22-2009, 07:12 PM
Nuke
Nuke's Avatar
I'm running out of sharp objects to stick in my eyes...
Nuke is offline
Old 01-22-2009, 08:12 PM
vaporstang
vaporstang's Avatar
Non-synthetic oil is fine. The only reason you may need a synthetic or blend is extreme conditions, i.e high temp, extreme cold, extreme time between changes etc. Back in the day when I was involved with (industrial) lubricants, synthetics were really strong in some areas and weak in others compared to standard oils. I'm sure synthetics have improved immensely since then.
I've used standard oils in all my vehicles until I bought my GT. Now I use synthetics, even though I believe it is overkill....
vaporstang is offline
Old 01-22-2009, 08:30 PM
07musclemustang
synthetic (whatever you choose) is best but should only be used once your motor is well broke in.
Go about 10K kms before switching to synthetic if you choose to. (6k miles)
synthetic is too slippery to allow proper break in
Old 01-22-2009, 08:48 PM
Goldenpony
Goldenpony's Avatar
Default Oil
Most all Super Cars (Corvette, Viper, Porsche, GT 500(I think)) come factory filled with Mobil 1
Old 01-22-2009, 09:25 PM
07musclemustang
dont forget that the srt8s come factory with synthetic but i still stand by my post that a engine must be broken it properly with a standard oil first
Old 01-22-2009, 11:41 PM
06MLPGT
06MLPGT's Avatar
Id say synthetic. In the long run it will be worth it.
Mike
06MLPGT is offline
Quick Reply: Oil change
