Traction Control Off When Supercharged?
My Whipple HO kit was finally installed and I was curious if anyone else heard that our traction control should be OFF all of the time because when TC is ON it can cause your car to run lean?
Traction control reduces throttle not fuel. Only downside I see to traction control is if you start to get sideways and it limits the throttle you end up facing the side of the road and drive off or into something.
Stability control > Traction Control
once you're boosted, it should be automatic; start car, turn off t/c.
if you can't handle your car without t/c, you may want to consider trading it in for a fwd.
