GT500 chin spoiler install question
Ok, so I installed the GT500 chin spoiler today following this guide:
https://mustangforums.com/forum/s197...-on-06-gt.html
I cut the parts on the left and the right, but the spoiler is still not fitting properly. It sags on those sides, and from what I understand they should fit flush, right? Anybody encounter this or have recommendations on what to try?
Yeah, I thought about that, but when you pull those sides up the center piece pushes on the front bumper, and the whole spoiler kind of contorts and gets wavy. I've read a lot of people talk about using door molding, so I might try and rig up something with that.
I've personally installed 2 GT500 chin spoilers and they have always fit flush under the GT bumper. The only thing that I had to do was add (2) additional screws/lag bolts (1 on each side) under the chin spoiler and into the bottom of the bumper to draw the chin spoiler up, so it didn't look like it was sagging.
below is the picture I marked up for another member...
i don't know if it would help any, but i cut off part of the top of the raised middle section of the splitter and mine fits near perfect now; there is still a little bit of a sag in the same area you are talking about, but not enough to cause concern
how high is it screwed in on the inner fender well? it almost looks like you need to raise it higher (if that makes sense)
No offense, but why would you do that???? The CS has a built in chin spoiler on the bumper. That would kind of be like bolting an aluminum wing on the top of a stock GT spoiler.
