Pony emblem
Yes, you have to remove the grill. It's the only way to get to those annoying little clips that hold the emblem on.
The hardware gripping the pins is non-user-removable without
breaking either the clips or the pins.
The new pony should have new clips.
You can access the whole schebang from under the stang
reaching behind the grill without removing it.
Just be sure not to cut yourself on or bend any
of the A/C condensor fins. Masking tape will
cover them until you are done. Just dont forget to remove it.
There are holes in the grill that the pins go into
like the new emblem will. Just hope they send you
new speed clips as well....
we carry the Unique Automotive Grill Emblems.
Sold a bunch to fellow forum members.
They look great!
Skeleton has been the best seller
But if you are feeling patriotic
Check them all out at www.southernmustangparts.com or click below
http://www.southernmustangparts.com/...4979fe5f92f2ec
Thanks!
Ken
They look great!
Thanks!
Ken
Ironically I had looked at your web site. In fact I am concidering the skeleton emblem. My only concern was the install since I have no prior exp. with taking apart the grill. When you ship the item does it come with instructions on such and also do you send the emblem with the speed clips as mention'd above that would be needed for the install?
Thanks
Thanks
They look great!
Thanks!
Ken
They look great!
Thanks!
Ken
I put the skeleton on my car a while back too...had to break the little posts off and the clips were fine to reuse. They're still holding tight after about 2 years. I took the grill out and it was my first time doing anything to the car so I had no experience. It is pretty straight forward and came out easy.
