Sponsored by:
Sponsored by:
Need Advice with Saleen Supercharger install
Old 06-19-2009, 06:10 PM
rcj2000
rcj2000's Avatar
Default Need Advice with Saleen Supercharger install
Ok guys im getting a 2006 saleen supercharger put on my 07 GT on June 29 and 30th. I have to order the coolant kit from brenspeed since mine is an 07 and was gonna get a smaller pulley and belt when i order the coolant kit.
1.)can the stock motor handle a 3.4 pulley that is suppose to do 9.5 psi. and about how much would this put down?
2.)i know im upgrading the injectors to 39lb ford racing injectors but not sure if i need to do the spark plugs also.
3.)i was already reading something about a "catch can" do i need one of these also?
4.) which one should i do, a dyno tune or a brenspeed tune through the xcal?
5.) any other parts neeeded to make this 06 kit, fit an 07?
also any other precautions, or extra things i need to buy/do for a good reliable install??
Thanks
rcj2000 is offline
Old 06-19-2009, 07:21 PM
graygt07
graygt07's Avatar
1. yes it will handle the boost, with a safe tune you will see 450 hp
2.yes get the plugs from brenspeed, they are cooler
3.no need for a catch can
4. the best tune is a dyno. if you cant dyno then xcal tune will work
5.you should be set, nothing else needed
take your time if you are installing your self and some photos
graygt07 is offline
Old 06-19-2009, 07:33 PM
rcj2000
rcj2000's Avatar
when you put down the 420rwhp...what size pulley were you running? also any other mods? stock saleen airbox or CAI?
and what about when you put down the 450rwhp?
Thanks for the help
rcj2000 is offline
Old 06-22-2009, 01:11 PM
rcj2000
rcj2000's Avatar
Ok i decided to go with the 3.6 pulley putting down 7.5psi that way i dont have to get the boost a pump kit.
Anyone running the 3.6 pulley, how much should i expcet to put down? thanks...
rcj2000 is offline
Old 06-22-2009, 01:39 PM
BRENSPEED
Former Sponsor
BRENSPEED's Avatar
our Stage 2 (3.6 pulley) typically puts down 400 rwhp. Our tuning is very developed and you should not need a dyno tune.
BRENSPEED is offline
Old 06-23-2009, 06:02 PM
rcj2000
rcj2000's Avatar
anyone know if the stock bullitt intake will fit on the end of the stock gt inlet tube like the steeda one does?
rcj2000 is offline
Granatelli Sales
01-20-2020 12:34 AM
09-03-2015 07:14 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Need Advice with Saleen Supercharger install
