Sponsored by:
Sponsored by:
Lowering Car = Cutting Bump Stops?
Old 08-24-2011, 08:46 PM
  #31
scottybaccus
scottybaccus's Avatar
Originally Posted by Norm Peterson
I think the Eibach stops could be made a little more progressive.
Norm
Did you notice how the Eibach pad is undercut at the bottom? I'm thinking in an effort to soften the final blow. It could also have something creating a progressive rate on the interior, like a cone shaped hollow, maybe.
Here's a link to their tuning guid for the universal motorsports stops:http://performance-suspension.eibach...s__bump_stops_
scottybaccus is offline
Old 08-24-2011, 09:51 PM
  #32
HenryinFlorida
HenryinFlorida's Avatar
When I lowered my car I used a set of these ford bumpstops:
http://www.cjponyparts.com/FORD-RACI...2011/p/M5570A/
There made for lowered springs. It's not that there shorter, but there made from a different material that absorbs more. I haven't hit bottom with my car yet, and it's lowered 1in in front and 2 in in rear. I used Roush Extreme springs and KONI STR.T shocks and struts.
HenryinFlorida is offline
Old 08-25-2011, 05:39 AM
  #33
Norm Peterson
Norm Peterson's Avatar
Yes. The chamfer is a little better than nothing.
Entirely possible.
Originally Posted by me
Unless there's some detail we can't see
I'd still wonder if a cone-shaped void in the solid thing would be as effective as just making the solid thing conical, though. But again, still better than nothing.
Maybe somebody will post up a couple of pictures . . .
Norm
Norm Peterson is offline
Old 08-25-2011, 06:26 AM
  #34
Norm Peterson
I see the picture, but this
Application Lookup
The application guide below will allow you to view a listing of EBS Eibach Bump Stops
After choosing the Desired Length, ID and Bump Stop--click on View Graph and Image for travel and rates along with the actual design. To select another--just return to the selections you wish to change and continue through the steps that follow.
doesn't lead me to where I can enter that data, or anyplace else useful for that matter. Maybe it's me (too early in the AM <yawn> ) or maybe it's the office internet connection filtering it out (grrr, dammit).
I seem to remember going through a bump stop stiffness vs height discussion or two over on an F-body board some years ago. I don't think it ever got quite as far as trying to estimate the lateral load transfer effect numerically, as a linear geometric roll center model based on the normal suspension linkage is no longer adequate.
Norm
Old 08-26-2011, 12:55 AM
  #35
scottybaccus
Here's an example of the data for one of the stops. It is actually a progressive rate spring.
djbigskrilla
09-20-2022 01:04 AM
inyadreems
08-21-2015 09:10 AM
jdphillips73
08-16-2015 04:34 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Lowering Car = Cutting Bump Stops?
