Lowering What do i need?
Okay, i wanna lower the car im getting the eibach kit from mike when i speak to him again, but is there anything else i need i mean anything else? i know i need correction bolts but anything else new bump stops end links for my sway bar?? i dont wanna buy the kit and then when i install it i need this that and the third.. thanks guys
You can just lower it with the springs....since you have 20's I would get an ADJ panhard bar too. First its an upgrade from stock and second if the rear gets a bit out of alignment the adj. PHB will correct it. Many will recommend new adj shocks too but IMO thats personal choice as many do without it esp for the street and if its not a DD. At some point you might want to get new shocks too as time progresses.
Depends on if you get the pro-kit or sportlines. Pro-kit all you really might need are camber bolts and an adjustable panhard bar. For sportlines you probably need camber bolts, adj panhard bar, adj upper control arm.
you really only will need springs, and eventually new shocks/struts.
but id get lca relocation brackets, adj uca, camber plates(for adjustment and more durable strut mounts), adjustable front endlinks, and an adjustable panhard. then an alignment.
