convertible tips and tricks
Is there a way to lower all the windows at once on a convertible? such as a combination press of a button on the fob or in the master switch?
Will it destroy the convertible top/mechanisms if the windows are left up when closing the top?
https://www.facebook.com/diyfordmustang
Well, just hold all 4 buttons down at once until the windows are down. Only the drivers door window has an automatic down. It probably wouldn't seriously mess up anything to put the top back up with the windows also up, but at least drop the windows a little first just so the seals line up correctly
As recommended by Ford, you should lower your windows before opening and/or closing the convertible top. Not doing so could result in tearing of your rubber seals. Plus the cost of replacing those seals is worth not taking the risk in my opinion.
