Sponsored by:
Sponsored by:
s197 Ecoboost
Old 01-08-2014, 03:03 PM
  #21
walt460
walt460's Avatar
Jim5.0,
Yep, the 2015 Mustang gets a 4cyl 2.3L Ecoboost at about 300 HP. But the 3.5L Ecoboost is going to continue in the F150 and I hear that for 2015 the F150 will get a all-new Ecoboost, a 2.7L (Nano) V6 that is even smaller and lighter than the 3.5/3.7L family of V6s. So there will be two V6 Ecoboost engines in the new 2015 F150.
I agree that both and GM will continue to create more power and even better FE in the near future. And I agree that NA V6 engines will be around 350HP. But the key for the 3.5L V6 Ecoboost is that 90% of peak torque, so around 400ft-lbs, is available from 1700 rpm through 5500 rpm. You just can not get that level of flat torque curve from a small displacement NA V6.
I also agree that since the conversion of a Mustang to a F150 3.5L Ecoboost engine and 6R80 will likely cost you about $10K to complete, that just spending $10K on a 3.7L will likely get you the same power and durability, or even more. I am not sure about the FE results, but i am certain that there are several good options to equal the power and durability of the 3.5L Ecoboost.
Personally, I prefer doing a swap using a factory-proven powertrain where I know the expected results can be achieved, that's all, just my thinking.
walt460 is offline
Old 01-13-2014, 06:16 AM
  #22
BrazenStang
BrazenStang's Avatar
Originally Posted by Norm Peterson
Only if you're running the F150 at full WOT repeatedly at, up to or just below redline, and rarely running it below about 4500 rpm.
Norm
I was reading an article about the 2015 F-150 this morning. It talked about running the EcoBoost engines in Baja 1000. I also remembered reading about this testing a couple of years ago when they were first coming out. If they can hold up to Baja racing, I'm sure they can handle a 20 minute track session.
BrazenStang is offline
Old 01-13-2014, 07:11 AM
  #23
Norm Peterson
Norm Peterson's Avatar
There is no way a Baja racer is running production stock cooling. Especially if forced induction is present. To keep an EB 3.5L Mustang cool and at least sort-of all Ford, you'd be hoping for uprated cooling to show up in the FRPP catalog.
Norm
Norm Peterson is offline
Old 01-13-2014, 02:15 PM
  #24
BrazenStang
Norm
Good point. Baja is still hours of grueling punishment. Its one hell of a torture test at full throttle... and they did that to a motor that had been driven 150,000 miles.
Old 01-13-2014, 05:20 PM
  #25
2k232
2k232's Avatar
& they also tore the engine down and everything was still in factory spec/tolerance's.....thats insane.
2k232 is offline
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
09-25-2015 09:06 AM
Quick Reply: s197 Ecoboost
