Sponsored by:
Sponsored by:
Aeroforce Wideband O2 Sensor (A/F)
Old 09-09-2009, 09:56 AM
vasman
vasman's Avatar
Default Reply from aeroforce:
Well according to aeroforce you do not need to open necessarily a 3rd hole. You can plug it in one of your rear O2 sensors:
Most people replace a rear sensor with the wideband. The rears can be turned off easily in software so as to not throw a code. I would not replace a front sensor, you need them for closed loop operation. Optionally, install a third bung for the wideband. Concensus is, and what I've found, is that the rear position when using cats reads about 0.1 A/F leaner than actual at WOT.
Todd
The problem is with the rear O2 off I cannot pass emissions here in Houston, so third hole it is...
vasman is offline
Old 09-09-2009, 10:09 AM
shanec
shanec's Avatar
My Aeroforce and their wideband arrived today. Their instructions say to up the bung 18 inches from the engine. Now that's not real practical with longtube headers. But is a far cry from the rear O2's.
shanec is offline
Old 09-09-2009, 11:39 AM
VistaGT
VistaGT's Avatar
If you've got a tune just replace the rear o2 with the wideband...the rear sensors will be turned off anyway. I have the same kit
VistaGT is offline
Old 09-09-2009, 12:07 PM
vasman
vasman's Avatar
I got a tune with O2's specifically on. (just passed inspection with it).
vasman is offline
Old 09-09-2009, 01:08 PM
VistaGT
VistaGT's Avatar
So turn 'em off then lol
VistaGT is offline
Old 09-10-2009, 01:27 PM
socalwrench
socalwrench's Avatar
You want the wideband as close to the collector as possible. I would put it 3-4" behind the collector. That should give you an accurate reading from all the cylinders on each bank.
socalwrench is offline
samseed101
01-31-2007 09:48 AM
Boostaddict
01-15-2007 06:26 AM
ruger311
11-13-2006 03:54 PM
ruger311
11-07-2006 11:06 AM
callmeebryan@tps
02-13-2006 09:37 PM
Quick Reply: Aeroforce Wideband O2 Sensor (A/F)
