Sponsored by:
Sponsored by:
Noise from shifter
Old 01-16-2010, 06:54 PM
nottey4.6
nottey4.6's Avatar
Default Noise from shifter
Hey guy, I want to start off by thanking you for all the info I have aquired from this forum. It helped alot with the purchase of my 1st mustang about a month ago. It is a 2005 gt 5 speed. It has 4900 miles on it and it bone stock....for now. I have recently been hearing some noise from the shifter area as i can only describe at "Chattering". I have done alot of research on synchros and everyone describes grinding and difficulty engaging 1-2 and 3-4 gears. My problem isnt anything more than audible. It engages fine and shifts smooth. It usually happens maybe once per outting. I only drive my car 2-3 times a week. But it chatters when the gear is engaged in 3rd 4th and 5th gear. When i engage the clutch it goes away, shift into next gear it the noise reappears. It isnt a painful noise and it doesnt sound like it is doing damage but is certainly not what i would expect out of a car with 5k. Any input would be greatly appreciated. Thanks again guys!
nottey4.6 is offline
Old 01-16-2010, 07:46 PM
thewarmachine
thewarmachine's Avatar
My transmiIssion has a rhythmic whine/chattrer/grind sound when in 5th gear. It's had it ever since I have been using aftermarket shifters, but I'm sure it has done it the whole time. Aftermarket shifters transfer a lot of transmission noise to the cabin.
thewarmachine is offline
Old 01-16-2010, 08:18 PM
KoolerSL2
KoolerSL2's Avatar
yes its normal with any type of aftermarket shifter.
even the factory one will transfer a bit of noise if you keep your hand on it all the time.
KoolerSL2 is offline
Old 01-17-2010, 11:40 AM
timmbo
timmbo's Avatar
All I have heard is a slight faint whine occassionally.
timmbo is offline
firehorse02
11-16-2015 11:28 AM
KingRando
10-02-2015 08:06 AM
Explosive
10-02-2015 07:45 AM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Noise from shifter
