Sponsored by:
Sponsored by:
what does gt suspension have that v6 doesnt?
Old 01-20-2010, 12:46 AM
Red Beast
Red Beast's Avatar
Default what does gt suspension have that v6 doesnt?
correct me if im wrong, but is the only diff a rear sway bar?
Red Beast is offline
Old 01-20-2010, 01:29 AM
Tylus
Tylus's Avatar
v-6 = 7.5 axle
GT = 8.8 axle
bigger brakes on GT. Sway bars
quite a bit more. you can go to http://www.newtakeoff.com
they offer complete GT axles that are ready to bolt into your car...might need a new driveshaft though.
Tylus is offline
Old 01-20-2010, 01:36 AM
Red Beast
Red Beast's Avatar
Originally Posted by Tylus
v-6 = 7.5 axle
GT = 8.8 axle
ya, lol, idk if u saw my other post but i was already planning on doa new rear axle. from that same site. does the v6 lack both fron tand rear sway bars?
Old 01-20-2010, 01:39 AM
Tylus
Tylus's Avatar
didn't see your other post...why you going to a GT axle? just for the sway bars?
no idea about what a V6 gets from the factory.
Tylus is offline
Old 01-20-2010, 03:16 AM
Red Beast
Red Beast's Avatar
no, i wanted 4.10 gears, and u cant do that with 7.5 rear end, its not big enough. so instead of replacing multiple things, i just thought id get the gt rear axle with the 4.10 gear setup
Old 01-20-2010, 12:52 PM
rmssch89
rmssch89's Avatar
The V6, without pony package, is only lacking the rear sway bar.
rmssch89 is offline
Old 01-21-2010, 11:04 AM
157dB
Cut & Paste Expert
157dB's Avatar
V6
31.5mm front sway
no rear sway unless PP then its 18MM
GT
34mm front sway and 20mm rear sway
Springs are different for the added V8 front weight
and the larger 8.8" unsprung rear end weight.
A GT front and rear sway bar upgrade is very do able.
Very go cartish results.
157dB is offline
Old 01-21-2010, 06:14 PM
Cusp
Cusp's Avatar
I think my Ranger has the 7.5 rear with 4.10s in it. At least the axle code on the door sticker tells me so.
Cusp is offline
Old 01-21-2010, 07:59 PM
Moderator
JimC's Avatar
Originally Posted by 157db
V6
31.5mm front sway
GT
Actually it depends upon the year of the Pony model. In 2006 it had the same front and rear sway bar as the GT (as measured by another member). In 2007 it had the smaller size if you opted for the rear sway bar. In 2008 it was back to the same size as the GT.
JimC is offline
Old 01-21-2010, 08:20 PM
Synyster06Gates
Synyster06Gates's Avatar
How is it not big enough? I have 4.10 gears in my 7.5''
Synyster06Gates is offline
Quick Reply: what does gt suspension have that v6 doesnt?
