Sponsored by:
Sponsored by:
Mileage on the 2011 GT?
Old 10-05-2010, 08:23 AM
pdonket
pdonket's Avatar
Default Mileage on the 2011 GT?
Just wanted to see what you guys were finding in terms of mileage estimates for your new 5.0s.
So far I've only used the onboard computer's estimate (which I do realize isn't all that precise) but I just wanted to know if everything is where it should be or not. I do basically completely city driving so far in the car, and living on a college campus makes stopping and accelerating an every block ordeal.
My computer is throwing out 15.8 MPG and I should mention that I'm driving pretty gently, occasionally I throw in a spirited start but most times I baby the throttle around here. The number just seemed a little low to me, but for all I know I might be wrong. Looking forward to hearing back from you guys though
Thanks,
Pd
pdonket is offline
Old 10-05-2010, 08:52 AM
chain1
chain1's Avatar
I've been averaging 12mpg. Just city driving
chain1 is offline
Old 10-05-2010, 09:14 AM
Nuke
Nuke's Avatar
Be sure you're resetting the on-board at each fill-up in order to get the most up-to-date data. If the on-board is anything like the ones in the 05-10's, it's off to the conservative (high) side by about 1-2 MPG. 15.8 is a bit low but could be normal for largely stop-and-go driving. Do a fill-up and then hop on the interstate for about 100 miles and see if that boosts the average by the next fill-up.
It takes a few thousand miles of varied driving to get a good feel for what your car's average MPG is. Even then, there are so many variables that you can't point to an exact number at any given time. But being able to distinguish REAL changes will keep you on the lookout for problems.
Nuke is offline
Old 10-05-2010, 09:42 AM
j0nx
j0nx's Avatar
Dear God! Are you racing from light to light or just average driving? I live in NoVa as well and there are lots of roads here where you can maintain 50mph or more for miles at a time. Man that is some awful mpg there...
j0nx is offline
Old 10-05-2010, 09:50 AM
Joe in Dublin
Joe in Dublin's Avatar
worst about 15, best on freeway at 70-85 about 22, average about 18-19
Joe in Dublin is offline
Old 10-05-2010, 10:02 AM
chain1
chain1's Avatar
That average is probably not that accurate. I have really only used my car to drive 1 mile into town and back for the 3 months that I've owned it. This trip involves 4 traffic lights and never exceeding 35mph.
Occasionally I take it down route 7 as well. If you're familiar with this road, you know that it's just Traffic light to traffic light. Basically 1st gear, 2nd gear, 3rd gear, stop. Repeat.
I do accelerate quite rapidly though. I get to use my car 2 days a week so I try to enjoy it while I can. For what it's worth I had the same average in my 07.
chain1 is offline
Old 10-05-2010, 10:36 AM
LostBoyz
LostBoyz's Avatar
sounds like you should've bought a bike
LostBoyz is offline
Old 10-05-2010, 10:40 AM
gatkins94
gatkins94's Avatar
I actually expected to see numbers a bit better than the earlier 4.6 models, but these seem to be worse. That's interesting. My 07 GT with 3.55 gears and manual transmission normally stays between 23-24mpg, but almost ALL of my driving is with the cruise control on.
I also reset the mpg's on the computer after each fill-up...I'm kinda **** about that for some reason...and occasionally I check the actual numbers against the computer and I've never found them to be that far off. Maybe a little, but not 1-2 mpg like someone else mentioned...and if you have a programmer, you can get real close by adjusting the wheel diameter.
Would like to see what others report on this, I had almost convinced myself as much as I drive that the extra mpg would somehow make it worth the money to trade up....now I think it would be a mistake based on that.....although the fun factor of the extra 100hp may still be worth it!
gatkins94 is offline
Old 10-05-2010, 10:48 AM
chain1
chain1's Avatar
I should also mention that I have 3.73 gears.
chain1 is offline
Old 10-05-2010, 11:01 AM
2011StangGT
2011StangGT's Avatar
I have been getting 18.something with mine and 3.73 gears according to the on-board computer.
2011StangGT is offline
Quick Reply: Mileage on the 2011 GT?
