Sponsored by:
Sponsored by:
View Poll Results: Twin Screw or Roots
Twin Screw
50
84.75%
Roots
15.25%
Voters: 59. You may not vote on this poll
Twin Screw vs. Roots
Old 12-09-2010, 01:35 PM
302_GT
302_GT's Avatar
Default Twin Screw vs. Roots
I know I'm opening up a can with this one. I know the basic difference between the two:
Roots compresses the air in the intake manifold (Eaton)
Twin Screw compresses it in the supercharger (Whipple, KB, Saleen)
It's an opinionated argument, just looking to hear your oppinions..
302_GT is offline
Old 12-09-2010, 03:08 PM
Burns331
Burns331's Avatar
Twin screw is the only way. Lower boost temps compared to a roots. and more efficiant.
Burns331 is offline
CutterWolf
CutterWolf's Avatar
Na, Centri FTW!
CutterWolf is offline
Old 12-09-2010, 03:35 PM
stealth_GT
stealth_GT's Avatar
The new 4 lobe rotors are the shizzy (Roots)
I like those. 3 lobe ain't bad.. plenty of older Cobras running in the 11s with them.
stealth_GT is offline
Old 12-09-2010, 03:40 PM
302_GT
302_GT's Avatar
LOL, I see the votes are pretty well speaking for themselves, and this was the answer I was expecting. But I was hoping for some more reasoning to back it up.
I'm curious to see how many people are familiar with eaton's Gen 6 TVS technology. The previous generation Roots SC's had obvious heat soak issues, but eaton seems to have made some major headway with the Gen 6.
My biggest argument with the twin screw is it's constantly creating boost. Even though it has a bypass so the boost doesn't make it to the engine, the SC still has the added stress of consistantly making boost.
Where the roots has the bypass before the internals, so the SC isn't under anywhere near the same load as a twin screw during cruising speeds. But you still get immediate boost at WOT.
302_GT is offline
Old 12-09-2010, 03:43 PM
rshamekh
rshamekh's Avatar
Generally, the TS has greater potential on the long run.
rshamekh is offline
Old 12-09-2010, 03:49 PM
outceltj
outceltj's Avatar
I went with saleen b/c i wanted power other than just wot. So u have to ask urself is that when u want to feel ur power. ONly in wot or at say half throttle. Its really up to u
outceltj is offline
Old 12-09-2010, 03:54 PM
302_GT
302_GT's Avatar
I may have mis-spoken on that last quote because I believe the bypass valve's work the same for both Twin Screw and Roots.
So in theory you should feel the same boost at 1/2 throttle for either kit.
302_GT is offline
Old 12-09-2010, 03:57 PM
Wally39
Wally39's Avatar
No it doesn't. I had a twin screw Saleen blower and the ONLY time it produced boost was if I accelerated faster than normal or WOT. Normal driving it's like any other car.
Wally39 is offline
Old 12-09-2010, 03:59 PM
302_GT
302_GT's Avatar
Isn't the bypass located after the internals on a Twin Screw though? Which would mean that the air is still being compressed by the rotors, then released by the bypass before going into the intake?
So your boost gauge wouldn't read anything (since most gauges measure the boost as it passes through the intake). But your SC is still going through the work of compressing the air.?
Again, this thread was just for arguments sake. I'm curious what the benefits of each are.
302_GT is offline
Quick Reply: Twin Screw vs. Roots
