Sponsored by:
Sponsored by:
How is the 6 speed MT on the new Mustang?
Old 04-04-2011, 01:07 PM
Will3212
Will3212's Avatar
Originally Posted by Joe in Dublin
Some have problems with rough shifting in cold areas. im in ca and when its cold or first few miles the shifting is rough, like any manual. if your in a cold climate, under 30 degrees your going to have to find a tranny fluid that works better in cold climate's, ford is working on it. as far as skip shift. any tune will delete it or u can disconnect it. it saves you $500 in gas taxes.....
to be honest i'm kind of debating about buying the mustang gt stick now because of this skip shift thing. I mean is it like super annoying? also can you please tell me what exactly happens, does the shift **** physically go from 1>4 by itself? can you just not let it goto 4 and force it into 2nd?
Will3212 is offline
Old 04-04-2011, 02:10 PM
LostBoyz
LostBoyz's Avatar
Just disable it and you don't have to worry about it. Its basically if you are light on the pedal, there is a solenoid in the shifter that prevents you from shifting to second, it directs you to 4th instead. It supposedly saves you fuel.
LostBoyz is offline
Old 04-04-2011, 02:54 PM
92hatchLX
92hatchLX's Avatar
It's not a huge problem. Most of the time you have to try and get it to do it. You can unplug the solenoid or when you get a programmer it can bypass it. It's no reason to switch transmission choices over.
92hatchLX is offline
Old 04-04-2011, 03:00 PM
AzPete
AzPete's Avatar
Yep...not a big deal. I unplugged mine a short time after I got the car. The time it would catch me is slow traffic, making a right turn, Shifting in the turn to accel, and then I would try to accel with traffic.....a bit boggy. Unplugged it and never worried.
Five min. job and tie the harness to another one close by to keep it from hanging down. It is on the top passenger side of the tranny, near the back.
AzPete is offline
Old 04-04-2011, 04:23 PM
MustangFTW
Guest
Posts: n/a
No, a message will come up on the dash saying 1st to 4th and it wont let you shift into second, as others said it takes 5 mins to unplug and requires no electrical skill
Old 04-04-2011, 08:00 PM
defan238
defan238's Avatar
My new 2011 does not have the skip shift in it
defan238 is offline
Old 04-04-2011, 09:08 PM
Joe in Dublin
Joe in Dublin's Avatar
Yes your 2011 does, they all do, aswell as the 2012.
Joe in Dublin is offline
Old 04-04-2011, 09:36 PM
AzPete
AzPete's Avatar
If it is a manual....it has it.....and you will find it at the wrong time.
AzPete is offline
Old 04-05-2011, 12:31 AM
HxCGuitars
HxCGuitars's Avatar
For the skip shift, I had it happen to me on an 06 Goat. Basically from my experience when you're going along and you're not flooring it (under the correct conditions as listed above) it'll come up and lock you out of 2nd. I just kept driving in first up the rpm range until it went away. I like listening to the rev up anyway.
It doesn't physically move to fourth, it just blocks 2nd if you try to go to it.
Edit: And apparently with the stang it's an easy unplug. Go for it!
HxCGuitars is offline
Old 04-05-2011, 01:39 PM
Will3212
Will3212's Avatar
should i take it to a Ford dealer and have them do it? i'm uncomfortable doing it myself
Will3212 is offline
Quick Reply: How is the 6 speed MT on the new Mustang?
