Sponsored by:
Sponsored by:
Determining axle ratio by VIN
Old 04-08-2011, 08:39 AM
LostBoyz
LostBoyz's Avatar
a dealer might be able to look it up, but that still doesn't garantee it was never changed, unless OP is the original owner (but I guess he should know then what it had in the first place)
Just saying the question was does anyone know how to get the axle ratio from the vin, I was just saying who would know how to.
LostBoyz is offline
Old 04-08-2011, 09:05 AM
Nuke
Nuke's Avatar
http://www.2005stang.com/gallery/alb...1/vincodes.pdf
Nuke is offline
Old 04-08-2011, 09:14 AM
LostBoyz
LostBoyz's Avatar
I'm aware of that, I'm also aware of our own database here at chrysler that I can pull up every sales code for any VIN of the past 10? years. I know ford would have the same system, just need a dealer or employee to look it up for you.
You could to it the old fasioned way and prop the back end up, mark your axle and driveshaft and turn the wheels and figure out the turn ratio. Seeing as how common it is to swap rear axles on our cars, I wouldn't even necessarily trust a sticker.
LostBoyz is offline
Old 04-08-2011, 10:11 AM
hawkeye18
hawkeye18's Avatar
This. The chalk 'n turn, short of disassembling the diff and counting teeth (or stampings), is the only truly sure method of knowing what gears you have.
If you have a manual, RPMs at a given speed in 6th gear (or 5th for the '10/-s) is a pretty good indicator.
hawkeye18 is offline
Old 04-08-2011, 10:52 AM
Norm Peterson
Norm Peterson's Avatar
I'd use 4th gear (2010 & earlier) or 5th gear (2011 & up) to simplify the math (the tranny ratio is 1.00).
But I think you'd get better results being one or possibly two gears lower, because you'd have better resolution as far as the tach reading is concerned.
Norm
Norm Peterson is offline
Old 04-08-2011, 07:43 PM
modman42
modman42's Avatar
I found it! I have 3.55's. Thanks everybody, I now know alot of different ways to find my axle ratio.
modman42 is offline
Old 04-08-2011, 08:17 PM
madmann26
madmann26's Avatar
This also can help,
http://services.forddirect.fordvehic...in=yourvinhere
madmann26 is offline
Old 04-09-2011, 07:35 AM
wcgman
wcgman's Avatar
oooorrrrr, you could lay on your back in the garage for 9.4 seconds and read the tag on the axle housing....If you arent the original owner, well, that tag could be wrong, but you could do the ol' mark drive shaft axle count game.
wcgman is offline
Old 04-09-2011, 09:05 AM
157dB
Cut & Paste Expert
157dB's Avatar
1. Axle tag.
2. Door jamb sticker code.
3. Jack her up and spin the driveshaft.
Count driveshft turns to wheel turns and do the math?
4. Open her up and count the ring gear teeth as
well as the pinion teeth and do the math.
157dB is offline
Old 04-09-2011, 01:28 PM
Nuke
Nuke's Avatar
How about using one of the speed vs. RPM spreadsheets for the 4.6L S197 and a GPS? Once you know your true speed (via the GPS), just plug all the parameters into the spreadsheet. The only unknown is the gear ratio. At least it'll get you close if not dead-on.
Nuke is offline
Quick Reply: Determining axle ratio by VIN
