Sponsored by:
Sponsored by:
Best o2 sensors
Old 04-17-2011, 05:20 PM
mattstang2007
mattstang2007's Avatar
Default Best o2 sensors
Well recently my front o2 sensors went out. What brand is the best to get? i did a search here and nothin; did a search on google and only found bosch but nothin that said if they were good or not. Thanks
If anyone has changed their o2 sensors and took pictures I would love to see them.
The ford dealer told me it would cost 450.00 to change them, so I am gonna do this myself.
mattstang2007 is offline
Old 04-17-2011, 06:57 PM
SpartaPerformance
SpartaPerformance's Avatar
Both front o2's went bad??? That's a bit suspicious, you're not going by "free code reading at Autozone" are you? Anyway the best O2 sensors are either Genuine Ford or Motorcraft, don't waste your time on anything else.
SpartaPerformance is offline
Old 04-17-2011, 07:32 PM
mattstang2007
lol yeah I went off the free scn from az. I did reprogram the car to see what would happen and the code is still there
Old 04-17-2011, 10:13 PM
SpartaPerformance
It's highly irregular for both front o2's to go bad, so your best bet would be to have a mechanic really diagnose the problem.
Old 04-20-2011, 11:45 AM
tx_zstang
tx_zstang's Avatar
You have some other issue. Depending on the codes, you probably need to clean your maf sensor and/or throttle body. Do a search on cleaning those.
If/when you do actually need front O2 sensors, as mentioned, stick with Motorcraft/Ford ones for best reliability and least issues.
tx_zstang is offline
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
Dathan
10-05-2015 05:52 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Best o2 sensors
