FRPP Cams Installed!
#21
I am replacing my valve covers this weekend. It would be a lot better if I were doing the cams too, but just the covers this time. I had a few questions about the install
Did the FRPP covers come with the cover bolts and/or grommets or did you have to reuse the original ones?
The workshop manual calls for two ford spec gasket removers (ZC-30 and ZC-31) did you use them or something else to remove the little bit of gasket sealant that is there?
you car looks and sounds great.
Sorry to revive an old thread.
The FRPP covers come with the gaskets and bolts needed to install. I didn't use the silicone gasket remover. I just used a plastic putty knife and the old sealer came right off.
A little tip... before putting on your new covers use painters tape to cover them up. Prevents them from getting scratched up during the install. Good luck with it and post some pics when you get done.
Thanks bud!
Luke9222
10-22-2015 11:55 PM
