Sponsored by:
Sponsored by:
Need help...s/c'd GT made 333rwhp...wtf
Old 04-22-2011, 05:32 PM
Lupo222
Lupo222's Avatar
Location: Camp Lejeune, North Carolina and Fort Lauderdale, Florida
Yes, there is a zip tie on there, however, the stop bolt is removed. I found on another forum something about the actuator bracket not touching the stop bolt and some guys getting very very low boost when it was touching.
Unfortunately, I don't have a boost gauge yet so I can't tell how much boost it is making. All I know for now is 333whp doesn't sound right at all...especially since i made like 337 or something like that BEFORE the supercharger...
Lupo222 is offline
Old 04-22-2011, 05:43 PM
Lupo222
Lupo222's Avatar
anyone get a close up of their boost actuator and the stop bolt??
Lupo222 is offline
Old 04-22-2011, 05:45 PM
Vader GT
Vader GT's Avatar
Take it back to the shop, they can read manifold/boost levels. Again, your a/f looks good so I'm guessing (just a stab) that it may be making little to NO Boost.
Vader GT is offline
Old 04-22-2011, 06:04 PM
Lupo222
Lupo222's Avatar
I'll take it back an have them check that but I'm really curious about this stop bolt thing...I can't figure out how to adjust the bracket...finding out the boost will just prove the shares theory here. I need to figure out why...
And I did put on a new belt and it doesn't slip like the first one
Lupo222 is offline
dmhines
dmhines's Avatar
Here ... just took these pics. Here is what mine looks like when car is NOT running ... Should also look like this under full boost. Looks like your screw is in WAY too far ...
dmhines is offline
Old 04-22-2011, 06:18 PM
Lupo222
Lupo222's Avatar
Ok that helps alot!! There was another forum that was saying that when the plunger hits the stop bolt, they were loosing boost, makin it seem that when it's further in like mine, that they made more boost that way...
Lupo222 is offline
Old 04-22-2011, 06:37 PM
dmhines
dmhines's Avatar
Supposedly the stop bolt is set for the most efficient closing of the butterfly valve that is turning boost on and off. Since your bolt is all the way down the valve may be going PAST closed and is opening again ... therefore no boost.
If you look at my picture ... Saleen chose that stop position to ensure the butterfly valve is closed all the way but not going past closed and begin opening again.
dmhines is offline
Old 04-22-2011, 08:06 PM
Lupo222
Lupo222's Avatar
now if only i could figure out how to pull it out more without removing the whole unit!
Lupo222 is offline
Old 04-22-2011, 10:06 PM
Lupo222
Lupo222's Avatar
well, i went to the Marlins game tonight...right before, I had played with the actuator a little bit, opening and closing it to see how I could get at that stop bolt. When I drove the car just now to get dog food, I pulled off my street and spun 1st and 2nd...It was FAST!! But then a few moments later, its like I lost it again...Could that bypass actuator be getting stuck or something??? I need a boost gauge...
Lupo222 is offline
Old 04-23-2011, 01:20 AM
stealth_GT
stealth_GT's Avatar
It's most likely an easy fix.. sounds like you're on the right track though. If that bypass valve is not closing, you're just loosing all that great boost.. no power.
stealth_GT is offline
Quick Reply: Need help...s/c'd GT made 333rwhp...wtf
