Sponsored by:
Sponsored by:
What Have You Made Yourself?
Old 11-05-2011, 08:20 AM
Norm Peterson
Norm Peterson's Avatar
Over the years with various cars . . .
Made/modified transmission crossmembers for complete powertrain or just transmission swaps. Modified floorpans for same. Re-mounted a spare tire once, becaiuse its well had been taken over with EFI fuel pumps, filters, and a surge tank that I fabricated from scratch.
Fabricated leaf spring shackles, stabilizer bar brackets, and other odds and ends.
Painted hoods a couple of times, whole cars 3 or 4 times. If I told you how, you might not believe. Here's the latest full car paint job, several years after painting.
Nonstandard extra frame crossmember.
Adapt bucket seats from different cars into mine (twice). A real PITA sometimes, but my lower back greatly appreciated it both times.
A little bit of body sheetmetal work with patch panels.
Every single complete or partial replacement exhaust system in the last 45 years or so.
Built my own bead-breaker so I could at least mount my own tires. Made a few other specific-use tools over the years, and adapted an engine harmonic balancer puller so it could also be used as a balancer installer.
Made up a few tools for doing wheel alignment.
Other stuff that I've forgotten about.
Growing up (in southeastern Massachusetts ), I had at least three outstanding examples of self-reliance to follow right there in the neighborhood. My Dad (now 92), my uncle, and my best friend's Dad. There wasn't much that those guys wouldn't tackle or couldn't figure out how to do.
Norm
Norm Peterson is offline
Old 11-05-2011, 10:38 AM
157dB
Cut & Paste Expert
157dB's Avatar
I made a Heavy-Duty Over-Engineered A-Arm brace
that Ford left off my 07 stang and have done many
electrical mods not offered by aftermarket companies...
Attached Thumbnails What Have You Made Yourself?-img_2626.jpg   What Have You Made Yourself?-img_2628.jpg   What Have You Made Yourself?-bracesmall3.jpg   What Have You Made Yourself?-braceno.jpg   What Have You Made Yourself?-brace2small.jpg
157dB is offline
Old 11-05-2011, 10:47 AM
Ditty
Ditty's Avatar
Also....my friend designed, programmed and builds compression testers designed for rotory engines. (He's an RX-7 guy.) They work very well on piston engines as well. He is also in development of a 8 cyl EGT system that can monitor all 8 cylinders for EGT, give an average for either and both banks, and an overall average. All in a package about the size of a standard radar detector. I'll be protyping the EGT system on my Powerstroke when it is all complete. (Buying the 8 EGT probes is all on me though...and he hasn't figured which ones he'll use just yet.) www.twistedrotors.com
Ditty is offline
Old 11-05-2011, 02:21 PM
808muscle
808muscle's Avatar
I custom fit catch cans for my motor and my trans, not difficult but I like how they turned out. Repainted all my emblems black. Installed all my mods with buddies helping cept my gears. Doing it yourself always feels good. At my track it seems everybody does their own work. Speed shops are not plentiful here. LOL
808muscle is offline
Old 11-05-2011, 02:41 PM
danzcool
danzcool's Avatar
Originally Posted by luckydawg003
I made a shorty antenna and did all the work myself on all my installs.
Ditto.
Originally Posted by Young_Gun
Made a shorty? You can do that?
Yeah, ylu take your stock antenna, remove the ball, cut the antenna down to the height you want, grind down the end so the ball will fit, loctite the ball back on, paint and mount. It's much better than the shorties you buy because they don't seem to have the "anti-whistle" twist, and they whistle above 70.
danzcool is offline
Old 11-05-2011, 03:27 PM
Young_Gun
Young_Gun's Avatar
Originally Posted by danzcool
Ditto.
I just ran into an issue with my antenna.
Some idiot (previous owner) tried to raise it by putting this flimsy adapter below the normal one.
It moves around and crap.
Young_Gun is offline
Old 11-05-2011, 03:52 PM
Syracuse315
Syracuse315's Avatar
Painted my new throttle body and plenum "Ford Blue", painted the pony black and dremmeled (sp) most of the honeycomb out behind the new billet grille. Also new LEDS all around (dash, dome lights, license lights) and wired the blue footwell lights to turn on and off with the dome lights.
Syracuse315 is offline
Old 11-05-2011, 03:59 PM
Milspec
Milspec's Avatar
Well, its not the car, but I figure everyone likes to see pictures, so this is when I cut off a bunch of ridiculous plastic from the back of my motorcycle...had to rewire the LED taillight...etc, etc...
BEFORE:
Milspec is offline
Old 11-05-2011, 04:03 PM
Thor
Thor's Avatar
I don't create or install anything myself
Thor is offline
Old 11-05-2011, 04:29 PM
Young_Gun
Young_Gun's Avatar
You will in good time
Quick Reply: What Have You Made Yourself?
