Sponsored by:
Sponsored by:
Wet Sanding
Old 11-07-2011, 04:11 PM
LordRipberger
LordRipberger's Avatar
Default Wet Sanding
Hey Guys,
What is the point of wet sanding? Is it for cars with really bad clear coats or should everyone do this once and then just maintain the wax?
Also, when you wet sand, are you removing all of the clearcoat?
Thanks.
LordRipberger is offline
Old 11-07-2011, 04:25 PM
shad2009
shad2009's Avatar
wet sanding is to remove deep scratches...you don't remove all of the clearcoat, but you do remove more than if you were polishing with a rotary...wet sanding is surely for people that know what they are doing, if you feel iffy about it, practice on a scrap part...you can do SERIOUS damage to your paint
shad2009 is offline
Old 11-07-2011, 04:40 PM
daredevil95
daredevil95's Avatar
wet sanding with 1000 or 2000 grit sand paper will give a super smooth finish. As mentioned above it blends in the deep scratches. Make sure you sand in one direction and use plenty of water and don't cut through....takes lots of practice to get the technique down. Follow up with wax by hand or buffer and you could have a mirror finish.
daredevil95 is offline
Old 11-07-2011, 04:47 PM
LordRipberger
So if I don't have deep scratches (just swirls that you have to be close up to see) but want that mirror look, do I have to wet sand?
Old 11-07-2011, 04:56 PM
daredevil95
is it a new paint job?
Old 11-07-2011, 06:15 PM
MustangFirstCar
MustangFirstCar's Avatar
You may find these helpful. I wetsanded some non-auto pieces I painted myself with these videos.
MustangFirstCar is offline
Old 11-07-2011, 06:51 PM
pdonket
pdonket's Avatar
If you only have swirls you absolutely shouldn't wet sand...you're risking major damage over nothing by doing that.
Use a dual action or rotary buffer instead with a polish on and do a good job, and your swirls will be gone, and you won't have to worry about eating through your clear.
pdonket is offline
Old 11-07-2011, 07:17 PM
danzcool
danzcool's Avatar
That would be a job for compound and a buffer, others know more about what it takes.
danzcool is offline
Old 11-07-2011, 09:16 PM
daredevil95
Try using clear coat compound and a orbital buffer.
Old 11-08-2011, 12:30 AM
LordRipberger
Yes and no. My brother sideswiped a tree last year so about half of the car has been repainted. Within the last year. But I have always used microfiber towels when drying and microfiber hand mit when washing. But I still see swirls and it doesn't look as good as it does in the pictures.
Quick Reply: Wet Sanding
