Front end shimmy!
maybe swap rear wheels to front, if gone swap one wheel back after the other, that should pinpoint to the wheel that is off balance.
if the "front end" shakes i'm not sure what that might be.
I have the same issue.... 2 balances, toe adjustment and its still there I stopped caring and have learned to live with it.
Shimmy in the s197 is common and a terrible headache. My winter setup (stock wheels) have virtually no shimmy and when I put on my summer setup, shimmy comes back. This body style just seems to be extra sensitive. As long as I've read on here, most people with shimmy issues never found a solution or cause.
I have it, both on my 2010 and now my 2012, BUT ONLY WITH MY TSW's which means its a balancing problem. Just cause you say they were "balanced" doesnt mean they were done correctly, and one of those metal pieces couldve even fallen off.
The stock rims and tires on my 2012 have 400mi on them and I never had a shake or anything until I put my TSW's on. I am 100% sure that when I put my stock rims back on for winter the shake on the highway will go away.
Hope this helps
Hope this helps
Did the problem begin with the new tires and balance? I had a similar problem with a new set of tires, took it back to the tire shop for re-balance twice with no luck. Then I went to a more reputable tire shop that had the Hunter Road Force http://www.gsp9700.com/ balance, When they were done the vibration was gone, ride was as smooth as glass.
+1 that the S197's have chronic vibration. Are your wheels OE or aftermarket? Aftermarket wheels require that you remove the wheel stud clip(s) that were usually left on some or all wheels during assembly.
th, smooth now.
