Sponsored by:
Sponsored by:
2005 conv (heated Seats)
Old 01-05-2012, 11:51 PM
Stang-aholic
Stang-aholic's Avatar
huh.... i also think i had some too... i would think ambient lighting, but that was after 06, could b sensors if u have a manual for an auto...
Stang-aholic is offline
Old 01-06-2012, 01:10 AM
Lem-06
Lem-06's Avatar
well i gotta poke around in my console to solder my bypass relay<went the lazy route on it first time, dont ask me why iunno>
May take a pic of them while im at it and see what you think.
Could be for the auto since im a manual.
Lem-06 is offline
Old 01-08-2012, 12:13 AM
Lem-06
Lem-06's Avatar
http://imgur.com/a/jgkQQ
heres the mystery connector in my center console. Sounds about right it could connect to auto since im a manual but not sure
Lem-06 is offline
Old 01-08-2012, 08:00 AM
Moderator
JimC's Avatar
Lem - do you have manual or automatic? If you have a manual then my guess is that is for the automatic.
JimC is offline
Old 01-08-2012, 10:10 AM
defiance
defiance's Avatar
It is for automatic as I have one and that plug plugs into the base of the gear shifter for whatever purpose that thing serves.
defiance is offline
Old 01-08-2012, 10:54 AM
defiance
defiance's Avatar
defiance is offline
Old 01-08-2012, 02:48 PM
Lem-06
Lem-06's Avatar
ahh then the mystery has been solved.
Lem-06 is offline
Old 01-09-2012, 11:42 AM
defiance
defiance's Avatar
Back to the topic though, I am assuming OP has abandoned us, here is a good thread involving OEM heated seats.
It would be complicated to add the OEM stuff because apparently ford has a box under the dash that cars with non heated seats do not have. Here 157db's post where he explains it very well.
You can read the rest of the story here.
Originally Posted by 157dB
The heated seats have an added relay block under
the dash that non-heated seats equipped stangs dont have.
It also requires the SJB to be reprogrammed to have the heated
seat logic in it.
So add step 4, going to the stealership for the SJB programming.
Way too complicated to warrant factory heated seats as an afterthought...
nOW USING THE oem SWITCHES TO CONTROL AFTERMARKET HEATED SEAT PADS WOULD FIT YOUR BILL, i BELIEVE...
fricken caps lock
defiance is offline
PaulH2
20
01-31-2016 09:48 AM
jrrhd73must
10-02-2015 09:17 PM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
GT350 S550 Tech
09-29-2015 03:29 PM
Quick Reply: 2005 conv (heated Seats)
