Sponsored by:
Sponsored by:
Is the harness needed for the OEM HIDs?
Old 01-23-2012, 04:12 PM
157dB
Cut & Paste Expert
157dB's Avatar
+1 on the halogens...
You need the OEM HID housings, the OEM HID ballasts and the OEM HID bulbs.
They should plug right into the OEM non-HID harness...
As the pic would indicate...
Attached Thumbnails Is the harness needed for the OEM HIDs?-hid_1_650.jpg   Is the harness needed for the OEM HIDs?-hid_2_650.jpg
157dB is offline
Old 01-24-2012, 09:41 AM
Mr.Bape
Mr.Bape's Avatar
Originally Posted by acquah20
My factory HIDs don't look like that at all, mine have a tint of blue in them, those pictures make them look like he just put halogen bulbs in and made it work or something.
Acquah can you post pics? What he did was spliced wires into the factory OEM harness using the HIDs.
Originally Posted by Lem-06
how bout post the line of it hitting a wall?
if your above a certain height the hid's should barely make any blinding light
Lem I will do that tonight. Sigh, I guess I will be searching around for the harness then. I went to the Tousley Ford website but didn't know what specific part it was.
Mr.Bape is offline
Old 01-24-2012, 04:14 PM
acquah20
acquah20's Avatar
Yeah i can a pic on my iphone when it gets darker out in about an hour or two, love the stock HIDs though and glad i have them
acquah20 is offline
Old 01-24-2012, 05:42 PM
acquah20
acquah20's Avatar
heres a few angles of the lights, they have a little blue tint to them in person i believe due to the way the light housing is which imo look better then any aftermarket lighting housing for our cars but they look white in these photos, yours in your photos look more yellow/halogen to me
acquah20 is offline
Old 01-25-2012, 09:09 AM
freyes
freyes's Avatar
This is what my modded OEM lights look like with Morimoto projectors and a custom wiring harness. $560.00 from sickhids.com
[IMG][/IMG]
freyes is offline
Old 01-25-2012, 09:37 AM
acquah20
acquah20's Avatar
[IMG][/IMG]
Wow that looks pretty cool, how did you get the projectors in the OEM light housing? The only complaint i have about the factory HIDs is that the lense is too close to the fog lights and they should be on that side like yours. Your pass side parking light looks different though from the other side?
acquah20 is offline
Old 01-26-2012, 09:39 AM
Mr.Bape
Mr.Bape's Avatar
Mr.Bape is offline
Old 01-27-2012, 08:05 AM
freyes
freyes's Avatar
The OEM lights have an amber cover that sits over the turn signal bulb. We took off that cover and put in an led bulb that has alternating amber and white leds. When you turn on the turn signal, like I did on the driver's side, you get the flashing amber light. Otherwise, the light is white, as seen on the passenger's side. My car is a 2011 supercharged V6. Only the Boss 302s and the V6 mustangs have the headlights on the outside. The V8s have the headlights on the inside and the turn signals on the outside. Oh, and the 2013 Boss 302 copied my turn signals. I say "copied" because I had mine before the 2013 Boss 302 was announced.
The only way to retrofit HIDs into the OEM headlights is to heat up the headlights and pry the cover lenses off the lights. Then, you install the Morimotos. The head light reflector was blacked out, but we kept the turn signal reflector the original "chrome" Check out sickhids.com. You can do this yourself, but sickhids does such a great job on the harness, that it appears factory made. My lights do not flicker, throw a fantastic, steady beam, and I believe, based upon lumen output, are better than the OEMS.
Check out theretrofitsource.com if you want to do everything yourself. There are full instructions on the web.
If your car is a daily driver like mine, buy a good OEM set of lights from ebay. Get the V6 lights, and send them off to sickhids.com. Mine cost $580.00. You will not be disappointed with the quality. He has a large backlog, so it will take some time to get your lights done. I wish I'd taken pictures of the wiring loom as it was a very professional job.
freyes is offline
Old 01-27-2012, 09:50 AM
Andy13186
Andy13186's Avatar
This would be a much better way imo than retrofitting HID projectors. Is this verified as possible, and if so, where can you buy the OEM hid housings, ballasts and bulbs?
Andy13186 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
MXBT187
08-20-2015 02:36 AM
Stilz
08-18-2015 09:40 AM
defarmer
08-13-2015 06:40 AM
$A_Money$81
08-11-2015 01:30 PM
Quick Reply: Is the harness needed for the OEM HIDs?
