Sponsored by:
Sponsored by:
dealer overfilled engine oil
Old 02-10-2012, 06:48 PM
2010stanger
2010stanger's Avatar
Default dealer overfilled engine oil
hay guys went in for an oil change and noticed on bill that they put in 6.75 quarts when the car only takes 6...........i went around the block and returned to get some oil drained. Would it have done damage to my car driving about a mile? im really worried
2010stanger is offline
Old 02-10-2012, 06:55 PM
Nuke
Nuke's Avatar
No, not after a mile or more. Over time it would have, though.
Just ANOTHER reason to learn to do your own oil changes. So easy, even a caveman can do it. And YOU pay good money to have some MONKEY do it. It actually takes less time to do it yourself, including any clean up, then it takes to drive to a shop and back.
Nuke is offline
Old 02-10-2012, 07:24 PM
2010stanger
how much play is there in the capacity? how much oil over the 6 quart would it take to do some damage? im sure there's a safety for issues like this! like vents to allow it to overflow?
oil level on dipstick was at the top hole
Old 02-10-2012, 07:47 PM
acquah20
acquah20's Avatar
I usually throw 7 qts in my 2010 4.6. I find 6qts fills it to the bottom line and 7 puts it just over the top off line. Not a big deal to me and im a tech at ford. The ford capacity chart we are provided at work i always find to be a little off and i personally like my oil at the max line
acquah20 is offline
Old 02-10-2012, 08:27 PM
2010stanger
when i looked at the level on dipstick it was at the top hole right after shutting off car! wouldn't oil level go up after car has been sitting for a while since all the oil in engine goes down to the oil pan? thats when we are to verify oil level right?
Old 02-10-2012, 10:30 PM
Nuke
Nuke's Avatar
If the engine has been running, shutting it off and letting it sit for a couple of minutes will provide enough time for enough of the oil to drain back to get a good indication. I prefer to check mine when the engine is cold but I have no problem trusting the reading when it's still hot.
The level on the dipstick should be anywhere up or down to and between the 2 holes (or whatever the high and low markings are on any particular dipstick)
Nuke is offline
Old 02-11-2012, 10:52 AM
157dB
Cut & Paste Expert
157dB's Avatar
Running and non-running oil levels are different.
Just because the receipt said 6.75 quarts does not mean
that there is actually 6.75 quarts of oil in the engine.
There is whatever the $7.75 an hour guy put in it.
Let her sit and check the oil on the dipstick with the
vehicle sitting level. Then stop worrying.
157dB is offline
Old 02-13-2012, 06:58 AM
highline
highline's Avatar
this...i used 6.5 my last go round...
highline is offline
Old 02-13-2012, 07:16 AM
D'prived
D'prived's Avatar
In my 2009 GT the manual says 5qts but I usually end up putting 5.5 to 5.75qts of oil to get it to the full mark on the dipstick.
D'prived is offline
Old 02-13-2012, 08:22 AM
highline
highline's Avatar
that's weird D...with a filter change?
highline is offline
Quick Reply: dealer overfilled engine oil
