Sponsored by:
Sponsored by:
My Dad's Engine Is Smoking
Old 02-15-2012, 03:04 PM
steveo555
steveo555's Avatar
Originally Posted by GrayPony
V6 or V8?
Does the cooling fan come on? Did you bleed the air out of the system when refilling?
V6 and I haven't heard the fan come on but I also wasn't listening for it. We did not bleed the system out just added more coolant the reservoir.
steveo555 is offline
Old 02-15-2012, 03:06 PM
steveo555
steveo555's Avatar
Originally Posted by edcologne
- does the gauge go to hot/overheat?
- as asked before does the fan come on assuming the gauge shows very hot eventually?
- heater getting warm?
- i wouldn't drive it, just let it run, check and observe.
mine warms up within a short time.
when cold/thermostat closed, radiator hoses should NOT be hot, maybe a little warm.
the gauge should go up (motor warms up) somewhat above center.
then thermotat should open, radiator hoses heating up, gauge go back a little and somewhat stay.
if so thermostat should be ok, but at 88k its a good idea to replace it anyways.
at some point then (keep an eye on the gauge) the fan should kick in, especially when not driving = no airflow.
* I didn't notice if it did or not. The guage does not go all the way to hot. It goes right to the middle.
* A tiny bit
* I have been at work today so I couldn't, otherwise I would.
Old 02-15-2012, 03:38 PM
edcologne
edcologne's Avatar
* A tiny bit
that does sound like circulation issues, hence thermostat.
found that, maybe helps.
http://www.allfordmustangs.com/forum...-how-pics.html
edcologne is offline
Old 02-15-2012, 05:20 PM
Moderator
JimC's Avatar
Head gasket? I had same thing happen to my car a couple years ago (still under warranty at that time) - never showed an overheating, but would blow the coolant out around the reservoir. Didn't show up in the oil either.
JimC is offline
Old 02-16-2012, 07:22 AM
White05GT
White05GT's Avatar
Are head gaskets in issue on V6's? Have a V8 myself but always like learning new things.
I'd replace the t-stat first and make sure all air is purged from the system. Or just take it to the dealer and get it checked.
White05GT is offline
Old 02-16-2012, 11:12 AM
kevinmalec
kevinmalec's Avatar
It could possibly be the upper or lower thermostat housing, which is made out of plastic. I've read it's a common thing with the 05/06 models. Many others have experienced this issue. Mine leaks off and on, which is very little.
kevinmalec is offline
Old 02-16-2012, 11:21 AM
ODDYSEY
Site Moderator of Fury!
ODDYSEY's Avatar
I would start with the thermostat as it is the cheap fix, and that doesn't solve the issue, look into taking it to a mechanic and checking the head gaskets.
ODDYSEY is offline
Old 02-17-2012, 08:13 AM
steveo555
steveo555's Avatar
Default Update!
Well we took it to a shop that was close to our house because the closest Ford is about 15 miles and that is way too far to drive with coolant issues... They looked it over and determined there was a crack in the thermostat housing. They are going to fix it for about $600.
Is this about the cost of what something like this runs with parts and labor?
Old 02-17-2012, 08:53 AM
ODDYSEY
ODDYSEY's Avatar
Sounds like your getting screwed, you can replace the thermostat housting in less an hour, and you should be able to get a new one for $100 bucks I would guess.
ODDYSEY is offline
Old 02-17-2012, 10:23 AM
bigblue95z
bigblue95z's Avatar
Yeah, that's a ripoff. No doubt.
bigblue95z is offline
Quick Reply: My Dad's Engine Is Smoking
