Questions/concerns after my upgrades
Questions/concerns after my upgrades.
A week ago I installed a Roush axle back exhaust. Yesterday I installed the Steeda CAI and SCT tune including the idle program “ghost cam”.
My first concern is the smell; it smells similar to a burning electrical or fresh welding smell. I don’t see any exposed wires.
My second concern is with the throttle. I understand that the tune improves throttle response but if I don’t press the throttle with a very smooth and consistent amount of pressure the car starts to jerk. It’s even more noticeable when I accelerate aggressively. I feel like I’m 16 again.
Lastly with the idle tune the car sounds like it’s going to die when I’m coming to a stop. Also the idle tune doesn’t kick in till I rev the engine after it’s warmed up.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
I recently added the JLT CAI and had the Bama Tunes programmed into my SCT. I don't recall experiencing those issues but the different tunes require me to run different octanes.
Here's a thread I found on the Ghost tune.
https://mustangforums.com/forum/5-0l...g-preview.html
OP, are you sure you can run both the "Ghost Cam Tune" and the "Steeda CAI Tune" at the same time? Usually it's whichever one you put in last is the one you are running. Did you have the Ghost tune written to include your Steeda CAI?
What did your tuner say when you told them about your issues you are having? If you haven't contected them about it yet, you should as only they know how your tune is writen.
The problems your having is most likely due to the ghost cams tune. The tune to replace the effect of a camshaft swap became available to the new 5.0s. Simply put they will NEVER give the same quality of lope or idle as an actual high lift camshaft. Even small things like that come with aftermarket cams, but not nearly as bad sounding as you make it to be. If you want it to be smooth I'd return the tune to stock and just do a 93 octane street or race tune if you're using a programmer.
@ the op, the smell is the exhaust,thats normal just coatings burning off, as for the tune , ummm that's how it works it runs rough like its running a big cam, and if you read the directions they state clearly that when starting the car warm the idle won't kick in till the first blip of the throttle, and when the car is cold it does not cam lope and the idle is... skippy yes, that's the best way to put it... let it warm up a bit it will be fine
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
